Author: Subject: Cheap and cheerful OR cheap and nasty!?
Chaz
posted on 22/11/15 at 01:03 PM Reply With Quote
Hi all,
Has anyone used one of these as a hydraulic clutch master cylinder?
Making a DIY hydraulic clutch for my MT75.
Universal Master Cylinder Brake Clutch Kit 3/4" 19mm Remote Hydraulic Handbrake
gregs
posted on 22/11/15 at 01:21 PM Reply With Quote
Originally posted by Chaz
Hi all,
I used a land rover master cylinder - just ebay "land rover master cylinder clutch" and you'll get lots more at or around that price.
For what it's worth I used one with an integral reservoir matched to a land rover slave - and not had any problems so far.
Greg
Chaz
posted on 22/11/15 at 01:33 PM Reply With Quote
Thanks gregs
Do you know any other donors with a 'pull' slave cylinder other than buying a new Wilwood one?
gregs
posted on 22/11/15 at 01:59 PM Reply With Quote
Thanks gregs
I used a push cylinder having drilled & tapped a hole into the bell housing and welded (against all best practise!) a lug on a well to carry the cylinder.
[img] Description
[/img]
Chaz
posted on 22/11/15 at 02:06 PM Reply With Quote
Think a push is a bit tight for me with an MT75!
gregs
posted on 22/11/15 at 05:19 PM Reply With Quote
maybe - needs about 60mm of space to the side of the release lever.
