Author: Subject: smal end bearings - where to find
bikecarbfred
posted on 3/1/16 at 12:43 AM Reply With Quote
Anyone know where in the uk sell a wide selection of small end bearings:
the size I need is :
OD: 21MM
Length: 20MM
I went through all the hard work in buying h beam rods and removing the wrong size bushings and now finding it hard to find the above type. Does not seem to be a big selection around on the net.
jacko
posted on 3/1/16 at 11:47 AM Reply With Quote
http://simplybearings.co.uk/shop/?gclid=CN7Cl_HIjcoCFScXwwod_6AJ2g
this any good
bikecarbfred
posted on 3/1/16 at 12:17 PM Reply With Quote
i will have to contact them because the bearing has to be Phosphor bronze
turbodisplay
posted on 3/1/16 at 04:10 PM Reply With Quote
It is possible to by bar and get it machined.
Darren
ALLAN 14
posted on 3/1/16 at 04:27 PM Reply With Quote
Hi Ithink you need to find an engine refurbishment workshop,as when you have put the bushes inYou will need to
have them reamed and honed to the correct size to match the gigeon pins with the reccomended clearance,
which will be very small and only achievable by honing by a machine lapper.
I would look for engine borers Diesel or petrol engines, as for the bushes they should be able to get them from a specialist supplier.
Hope that helps.
Allan.
