Author: Subject: Which Type 9 Gearbox Mount
J90rdn
posted on 12/1/16 at 12:31 AM Reply With Quote
Need to get a new type 9 gearbox mount for the tiger avon. It will be a pure track car, and linked to a blacktop producing circa 170bhp - although in future may push up to 200bhp.
Should I get the standard mount (about £28) from somewhere like GBS?
http://www.kitspares.co.uk/index.php?route=product/product&product_id=461&search=mount
Do I get the Westfield one?
http://parts-shop.westfield-sportscars.co.uk/index.php?route=product/product&product_id=718&search=type+9+mount
Or do I get something like this?
Kit Car Ford Type 9 Gearbox Mount Vibra Technics (95mm bolt) Comp FOR168MX
furryeggs
posted on 12/1/16 at 04:18 AM Reply With Quote
dont do what i did and buy the wrong one, theres 2, The avon uses the wider one, the smaller one is slightly rounder at the ends and is narrower.
HowardB
posted on 12/1/16 at 07:39 AM Reply With Quote
my fury has the top version fitted, it came in 2 flavours - standard and HD, having just broken a standard I bought a HD one, it was something like £15 from a trade counter place in Aberdeen,...
Howard
posted on 12/1/16 at 08:44 AM Reply With Quote
IIRC I got a new HD one from my local Ford dealer. Less than £20 and the box didn't move once installed either.
mcerd1
posted on 12/1/16 at 12:42 PM Reply With Quote
here's the sizes:
Sierra type
Cortina type
the Cortina one (also caterham, westfiels etc...) is much stiffer, but also narrower and a a little taller too (ie more height difference between the centre and the sides)
of course you can use either, but if your chassis already has brackets for one type then it will need some mods to suit the other
posted on 12/1/16 at 01:16 PM Reply With Quote
Looking at the above photo, I used the narrower one. Maybe not from a Ford dealer but either way less than £20.
