Author: Subject: Engine Change
ptrbrooker
posted on 2/5/16 at 09:15 AM Reply With Quote
Engine Change
Hi
I'm sure this has probably been covered before but i couldn't find anything. Anyway, I built my car from the original book with a 1300cc kent engine and got it on the road in 2002. Over the years I tuned the engine , Gas flowed head, cam etc.. but it got very tired so I replaced it with a black top 2.0l Zetec which I was lucky enough to buy new at a very good price, Megajolt and 45 DCOEs. So my question is when I notify the DVLA am I going to have problems with the emissions ,IVA etc any advise please on the process involved would be gratefully received .
Many thanks Peter
Dick Axtell
posted on 2/5/16 at 09:39 AM Reply With Quote
Emissions regs may well become a problem, if your engine is of post-1995 manufacture, when you have the car MoT-ed. I'll be facing the same problem later this year. Check out cats on Ebay; you may have to fit one in your exhaust.
DW100
posted on 2/5/16 at 09:48 AM Reply With Quote
Is it already registered and has it been used on the road as a 1300 crossflow?
If so then it is just a change of engine and the original emissions standards will still apply. No need for IVA.
[Edited on 2/5/16 by DW100]
benchmark51
posted on 2/5/16 at 10:01 AM Reply With Quote
I have the same thought. A 1300 xflow in at the moment, have a 205 pinto, short sumped, FR cam, twin 40 DLHA's, 4 into 1 ready to go in but haven't used it yet. Also got a ST170 recently and have been thinking about using that but don't know how that will affect the MoT ect.
ptrbrooker
posted on 2/5/16 at 01:20 PM Reply With Quote
Engine change
Hi
Thanks for the info.
Yes it is registered and has been used on the road so hopefully I just need to send Reg Docs to the DVLA with the receipt for the engine, fingers crossed .
Thanks I will keep you informed.
Peter
Kdempsie
posted on 2/5/16 at 01:31 PM Reply With Quote
I changed the engine on my last car from a pre 1995 1.8 to a new 2.0 Blacktop. There was no change to emissions but they initially rejected my engine receipt because it didn't have the engine number on it. There was also some suggestion of having a garage provide a receipt to prove it had been fitted but I explained I had built the car originally and had also done the engine change.
I don't remember 100% but I think I also sent a few pictures to support my application to change the V5.
Keith.
gremlin1234
posted on 2/5/16 at 03:54 PM Reply With Quote
from MOT testers manual, sec 7.3
Vehicles fitted with a different engine must be tested to the requirements of whichever is older, the engine or the vehicle. e.g. A 1995 car fitted with a 1991 engine (of whatever make), test to 1991 standards for emission purposes. Note: The onus is on the vehicle presenter to prove engine age.
I think the main reason dvla are fussy on engines, is so they can tax it correctly
plutos3
posted on 2/5/16 at 04:54 PM Reply With Quote
Remember guys if you have a Q plate its not a problem
DRC INDY 7
posted on 2/5/16 at 07:33 PM Reply With Quote
Unless it states on you logbook the emission levels.
Not all Q plates are checked for smoke only.
Puddle Dodgers Club
40inches
posted on 2/5/16 at 08:53 PM Reply With Quote
But they should be, the MOT manual states clearly that they are to be tested on smoke only.
Section 7.3, page 1, bottom left paragraph.
