Author: Subject: HELP i need an engine wiring diagram for dummies
Vindicator666
posted on 7/6/16 at 04:52 PM Reply With Quote
Hi all,
has anyone got a diagram for wiring loom for the engine, the wiring i have is standard ST 170 if that helps.
what i need is the basics of fuses and relays to install as i have the engine running starting and stopping ect but the wires are just bolted together in 3 parts perm live, switch live and earth.
im sure its easy once you get started but at the minute its a birds nest of wires
i have a 10 fuse box and flip switch push start 3 acc panel from ebay and thats it.
if anyone can email a simpletons diagram as to what needs fusing/relays that would be most helpful
Regards Tobe
snowy2
posted on 7/6/16 at 05:26 PM Reply With Quote
There is a post in the fuel injection section....just about the st170
sometimes you are the pigeon, most of the time the statue.
Vindicator666
posted on 7/6/16 at 06:53 PM Reply With Quote
thanks
Thanks snowy,
i can only view up to page 6 as that is all it says there is, wasa tried sending me a link to page 13 but all my devices will only access page 6 and no more.
can you email me the diagram direct please? tobeleigh@hotmail.com
Regards Tobe
mcerd1
posted on 8/6/16 at 10:21 AM Reply With Quote
click on the 'control panel / options' bit at the top of the page - then change the number of posts per page to 500 or 1000...
that way you can have the whole tread on 1 page if you like...
[Edited on 8/6/2016 by mcerd1]
