Plastigauge shelf life??
r1_pete - 12/2/17 at 09:58 PM
I was measuring the crank / bearing clearances earlier, with micrometers things were well in spec, looking like zero crank wear, and the bearings ar new and measured up correctly.
However a double check with plastigauge showed too much clearance, the plastic has been open about 9 months, so I assumed it had passed its shelf life.
But a google search shows about equal results for it having a shelf life and not, does anyone have a definative, I can see it drying out once the cellophane is opened??
perksy - 12/2/17 at 10:23 PM
To be fair its pretty cheap, so just get a new packet ?
I always use it for checking clearances and just use the mic's for checking ovality and taper on crank journals
r1_pete - 12/2/17 at 10:34 PM
Yes I agree, its cheap enough, I just wondered if it had dried out and was giving me a false reading..... I does seem to have gone a duller red from what I remember....
Bluemoon - 13/2/17 at 07:55 AM
You can always ring them up and ask...
