Author: Subject: Rev limiter config zetec
markpost
posted on 16/3/17 at 08:26 PM Reply With Quote
Hello Guys,
I'm searching for the right parameters for the Rev limiter.
I have a zetec blacktop 2.0 with itbs with a megasquirt ecu.
Peak hp @ 6000 rpm. I want the hard cut at 6500 soft -200.
But what do i use spark cut first then Fuel cut? I dont have a cat.
Thanks guys!
Greetz Mark
[Edited on 17/3/17 by markpost]
Ugg10
posted on 16/3/17 at 08:34 PM Reply With Quote
No basis for this statement but I would cut fuel before spark otherwise you will be pumping neat fuel/air into a hot exhaust that may cause ignition in the exhaust. Had an issue with the coil drivers blowing on an ecu. Drove the car on two cylinders a mile home, the cat on that care made a great furnace!
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
Schrodinger
posted on 17/3/17 at 03:53 PM Reply With Quote
I would counter that by saying I would cut the ignition for the soft cut as you will be running lean and risk burning a hole in a piston cutting fuel but would cut both for the hard cut.
Keith
Aviemore
