Author: Subject: Pump Noise and no return pressure.
ken555
posted on 1/5/17 at 03:15 PM Reply With Quote
Been having all sorts of problems over the last week or so.
The car will idle fine for 45 minutes, but once on the road, it runs for about 5 mile then starts to stutter/stop.
Dip the clutch and the revs pick back up.
I suspect the pump has had it, removed the pre-filter to check it was getting enough and still the problem is there.
How noisy are peoples external pumps ?
not the lack of return flow/pressure on the 2nd video.
theconrodkid
posted on 1/5/17 at 04:50 PM Reply With Quote
sounds like it,s sucking air
who cares who wins
pass the pork pies
View User's Profile E-Mail User View All Posts By User U2U Member   theconrodkid 's Aim   theconrodkid 's Yahoo
ken555
posted on 1/5/17 at 05:31 PM Reply With Quote
But where from ?
Takeoff at bottom of tank, pump level with it.
A small pre-filter, which I've removed and same effect.
About 3" of fuel pipe, which I've replaced, each side of filter before pump.
I would expect there to be a leak of fuel, if it was sucking air in a hole.
posted on 1/5/17 at 09:31 PM Reply With Quote
Check the tank air vent is clear , symptoms fit the pump trying to pull against partial vacuum in the tank.
[I] What use our work, Bennet, if we cannot care for those we love? .
ken555
posted on 1/5/17 at 10:26 PM Reply With Quote
Tried running with the filler cap off, no difference.
I have ordered a new pump to be safe.
But stripped the system down tonight, tried the pump in a bowl of petrol, powered by a PC power supply.
All appeared fine, connected it all back up, but with the pump hanging under the tank, and again powered by PSU.
Plenty of pressure and flow.
Now waiting for the residual pressure to disperse so I can disconnect the feed to the fuel rail to mount the pump back where it was.
So either its a power problem (Its fed via a switched relay, so I don't think so) or something was causing an air lock.
The pump is just mounted with a couple of large "jubilee" clips, just tight enough to compress the foam sleeve, level with the bottom of the tank. Can't see that being a problem, but going to leave them loose until I test it.
We'll wait and see tomorrow night.
[Edited on 1-5-17 by ken555]
theconrodkid
posted on 2/5/17 at 07:31 AM Reply With Quote
is this the Bosch type pump with the large inlet ?,i made the mistake of using a too small tank outlet (converting from carb to injection using same tank) causing the pump to struggle,remember these pumps suck at sucking,other than that still sounds like it,s sucking air,got any clear fuel pipe so you can see if there are bubbles coming through ?
who cares who wins
pass the pork pies
Schrodinger
posted on 2/5/17 at 08:08 AM Reply With Quote
You have checked that there is actually plenty of fuel in the tank?
Keith
ken555
posted on 2/5/17 at 03:09 PM Reply With Quote
Plenty of fuel, had added another 25 l to be on the safe side.
The pump has 10mmx1, in/outlet I have them fitted with M8 hose tails.
jeffw
posted on 2/5/17 at 04:27 PM Reply With Quote
Do you have a fuel pressure gauge? If not, you should as it will save you hours of fault finding.
So, to be clear, you have it connect as
Tank
filter
HP pump
fuel rail
FPR
return to tank?
with the fuel pump controlled by the ECU?
623BHP @ 10200 rpm with 1.75Bar of boost. 2Bar coming soon
jeffw
posted on 2/5/17 at 05:34 PM Reply With Quote
I reckon it is a fault regulator which is not opening and causing the pump to run at max pressure all the time.
ken555
posted on 2/5/17 at 07:50 PM Reply With Quote
Tank
filter
HP pump
fuel rail
FPR
return to tank?
Yes
Tank
40 micron filter
HP pump WALBRO GSL393
Pipe to engine,
10-20 micron filer
Fuel Rail with FPR on end
Return pipe to tank. feeds in about 5" from the outlet.
Pump fed from a relay, controlled by switch on dash, with inertia switch for safety
ken555
posted on 2/5/17 at 07:52 PM Reply With Quote
Was another idea, last night when it did work, I sucked on the vacuum line to the regulator, and you could hear the pump working harder.
But I do wonder if it was sticking once warm.
Don't have a pressure gauge, but will try borrowing one.
jeffw
posted on 2/5/17 at 09:21 PM Reply With Quote
Is the FPR adjustable? It would explain some of the symptoms if it was set wrong. I've found it best to use a specific pressure FPR.
jeffw
posted on 2/5/17 at 09:40 PM Reply With Quote
Originally posted by ken555
Yes
Tank
40 micron filter
Pipe to engine,
10-20 micron filer
The relay should be controlled by the ECU as it will only run it when the crank signal is seen....stop the engine and the fuel pump stops.
ken555
posted on 2/5/17 at 09:59 PM Reply With Quote
We may have a semi-winner.
Connected the compressor to the fuel feed line (Pressure is pressure, no matter if liquid or air) , and the FPR opens at around 36psi, according to the Honda manual the allowable range is 33 - 39 psi.
Connected everything up and no noise from the pump and a good flow from the return.
I now also have noise from the FPR that I didn't have before, a sort of gurgle/hiss/flow sound.
Everything is back together the way it was, nothing has changed.
So I wonder is with sitting the FPR had gummed up and somehow has cleaned it's self out with the little flow that there was.
Car has been sitting, with only the odd start/idle.
[Edited on 2-5-17 by ken555]
mark chandler
posted on 2/5/17 at 10:41 PM Reply With Quote
Bit of rubbish floating around in the tank blocking the inlet would also explain it, power down the pump and it drops away.
If you have a bare tube in the tank it needs a fish mouth end so something flat cannot block it, better still a corse filter over the end as well.
jeffw
posted on 3/5/17 at 05:20 AM Reply With Quote
Great, pleased it is working again.
ken555
posted on 26/6/17 at 09:22 PM Reply With Quote
It worked for a while, and on the way to my MOT gave a few splutters, then had a nightmare on the way home.
Decided to swap the pump, and on removing the hose tails to fit to the new pump, found this inside the pump inlet.
Swapped the pump to be sure and will wait and see.
ken555
posted on 27/6/17 at 01:10 PM Reply With Quote
So not pump related
Run fine last night, then happened again on the way this morning.
Wonder if it's a vapour lock, due to design, the feed/return runs down the same tunnel as the cooling pipes.
jeffw
posted on 27/6/17 at 01:28 PM Reply With Quote
Check your fuel filters, if that is what is in the pump inlet what is in the filters?
ken555
posted on 27/6/17 at 08:36 PM Reply With Quote
Filter are clear, pre-pump.
Happened on the way home tonight again, even with a full tank.
Tank was cool to touch. after about 2 miles of jerking it cleared and run the 10 more miles home ok.
Going to fit a clear fuel filter pre-pump to see whats happening on the intake and going to remove the fuel regulator for a look at it.
Also planning to run some air backwards down the fuel pipes to check for blockages.
