Author: Subject: CVH Hieght
eenud
posted on 17/10/02 at 09:53 PM Reply With Quote
CVH Hieght
What is the height difference between a CVH and a Pinto?
Ian
jcduroc
posted on 4/11/02 at 10:26 PM Reply With Quote
Ian
A CVH is 19.7 in high and a Pinto is 18.25 in high.
Joćo Carlos Matoso
Stu16v
posted on 4/11/02 at 10:41 PM Reply With Quote
Are you sure? It is a long time ago, but i am sure that when I measured the height of the Pinto in my mates car (with slightly modified sump) it came to approx 24" from sump to rocker cover.........
James
posted on 5/11/02 at 11:45 AM Reply With Quote
Just measured my 2.0 EFI Pinto and sump to rocker is 605mm (23.8").
Is it possible that your 1.6 pinto is shorter than the 2.0? Maybe...?
James
theconrodkid
posted on 5/11/02 at 07:03 PM Reply With Quote
as ford use the same bore and ajust the stroke you could be right james,ps you going to pick up the oval?
Mark Allanson
posted on 5/11/02 at 07:12 PM Reply With Quote
I measured a CVH today at work, It is 32" from cam cover(inc filler) to the floor and 7" of ground clearance under the sump making it 25"
Hope it helps
Mark
eenud
posted on 5/11/02 at 09:59 PM Reply With Quote
CVH Hieght.
Thanks folks, I had assumed that the CVH was lower, so thats plans A out the window. It may have to be back to looking for a X flow to keep the height down.
Ian.
