Author: Subject: Radiator design. Please help.
TimC
posted on 3/1/18 at 01:28 PM Reply With Quote
So, as I expected, my 2nd hand radiator isn’t fit for the job - I won’t bore you with the moot point as to why this is but it’s ‘broken’ rather than proven to be too small.
I’m going to commission a new one. I can order it in the same dimensions as the knackered one or I could utilise some available height and make it 75mm taller.
While bigger is on the face of it preferable, I’m not 100% clear on the interplay between the radiator bleed and expansion bottle. Currently the bleed is significantly lower than the expansion bottle which is as high as it can be. If I increase the height of the rad, the bleed will move vertically toward the bleed-inlet on the expansion bottle.
Are there rules of thumb that I should apply? Should I keep the radiator bleed and therefore the radiator-in-totality lower? If I’m okay to raise the bleed-outlet, is it okay if the small hose to the expansion tank heads down (to the top of the chassis rail) before rising up again to the tank?
‘Tanks’ in advance.
Sam_68
posted on 3/1/18 at 06:07 PM Reply With Quote
Water is heavy. If you're truly certain that your old radiator was big enough, had it been functioning correctly, then why add more weight in the extreme nose of your car than you really need to?
Having said that, height of the expansion bottle isn't that critical with a pressurized system. I used to run the expansion bottle on my Sylva so low that it's cold level was well below the bleed valve... I used to dismount it from its bracket and hold it up in the air when I bled the system.
posted on 3/1/18 at 08:18 PM Reply With Quote
What engine? What tune?, what radiator?
What cooling set up: grill, opening, fans etc.
How is it failing?
TimC
posted on 3/1/18 at 08:53 PM Reply With Quote
Hi Martin, I keep forgetting that you’ve moved ‘far-East.’
I’ve no real idea about the effectiveness of the radiator had it not been unserviceable - it’s ex-race R500 but the cars are totally different. I’ve only ever run the car near-static and with the ineffective unit. The 4C8 R1 has a real reputation for running hot with catastrophic consequences so I’m leaning towards the slightly larger unit if that could make the difference and isn’t going to upset the flow of coolant . Hmm.
Sam_68
posted on 3/1/18 at 09:07 PM Reply With Quote
Well in that case, as I said, my solution was simply to make the small diameter hose that links to the expansion tank a bit longer than it needed to be, and take the tank off and hold it up in the air to get enough head when you're bleeding the system.
Once the system is bled, if the cap on your header tank is airtight I can see no reason why you wouldn't be able to have the expansion tank below the level of the bleed and the top of the radiator, even (in fact, I think mine was, from memory).
You'll risk airlocks if there is any localised boiling, perhaps, but if that happens, you've got a problem anyway. Otherwise, the function of the expansion tank is just to allow for expansion - not to act as a swirl pot - so provided there is some volume of gas in it to be compressed, it doesn't matter where it is.
Yes, about as far east as it's possible to get without falling into the North Sea, these days, and my God is it bleak at this time of year - beginning to wish I'd stayed in balmy Gloucestershire!
TimC
posted on 11/2/18 at 11:40 AM Reply With Quote
I thought I’d update on where I got to on this.
I’d normally use Allisport for all things aluminium but they are incredibly busy - and admittedly not the cheapest- quality costs. Anyway, since Andrew @ Allisport had said they were struggling time wise and because the new rad was a slightly nasty surprise (unbudgeted) I had a look around and found Custom Made Rads via eBay. I ended up sending the old rad up to Darren with a list of changes - including thicker core. I’m really pleased with result. Admittedly the welds aren’t quite as pretty as Allisport’s but it was a good chunk cheaper.
Static temps are good - the new fan doing its job nicely. I went 65mm taller than the old one by the way as it made packaging easiest.
Worth a look if you are in the market for a new rad cmrrads@yahoo.com.
NewRad1
NewRad1
NewRad2
NewRad2
NewRad3
NewRad3
posted on 11/2/18 at 07:10 PM Reply With Quote
My comments so don't be offended.
1. F++++ me that is a huge oil cooler!!! Overcoming oil is not a good thing.
2. For best efficiency oil cooler should be against the radiator, refer to think auto website, I understand having the two far apart is a bad thing.
3. You should have a cowl to draw air through the whole radiator. The cowl would seal up against the frame, although your fan is close to the matrix, it is not a good seal as you'd get with a cowl. Also you are not drawing air through the whole matrix.
4.i do not look those brackets, wouldn't be necessary with a cowl.
Remove. cowl, either find car with same size radiator or make one.
There, I've said it.
Of course if all is well and oil temp is fine, ignore me
[Edited on 11/2/18 by 02GF74]
TimC
posted on 12/2/18 at 12:32 AM Reply With Quote
Those are all understood. I’ll let you know how I get on but system has been considered with specific engine in mind (and a series of racing failures when not carefully managed. GRP cowls and ducting are likely additions.
We will see.
