Author: Subject: shortened baffled big wing xe xev sump
blakep82
posted on 18/6/20 at 11:10 PM Reply With Quote
i got the sump off an ascona, cut the bottom off at 7 degrees, as my engine is tllted, and to clear the chassis, i've had to cut 50mm off one side, to 30mm on the other to achieve the angle
all good so far. i'll need to shorted the pick up pipe, and thats ok.
the piece i cut off is exactly 1L volume, which i intend to add back in with adding wings, one at 0.8L volume, one at 0.4L volume
the sump is the same as this one https://www.ebay.co.uk/itm/332525929579
what level does the oil ACTUALLY got it? up past the flattened area?
my intention is to put a baffle on top, like this
https://i.ebayimg.com/images/g/aTsAAOSwMLBan96I/s-l1600.jpg
to catch the oil, and wings on the sides
seems fair?
cheers!
________________________
posted on 19/6/20 at 07:30 AM Reply With Quote
If the engine is sitting in the chassis at the same angle as it was originally then the oil level at max on the original dipstick is correct, just make sure the dipstick doesn’t foul on the modified sump , you may? have to trim the bottom end of the dipstick.
