Author: Subject: Pinto Engine number
helen & phill
posted on 5/3/05 at 08:01 PM Reply With Quote
Pinto Engine number
Probably a simple one but could anyone tell me where the engine number is on SOHC Pinto 2.0
http://www.velocityxt.co.uk/
carlgeldard
posted on 5/3/05 at 08:13 PM Reply With Quote
Engine Number
Under the exhaust manifold and at the back of the altenator
Carl
helen & phill
posted on 5/3/05 at 09:18 PM Reply With Quote
cheers i'll have a wander out to the garage and get
helen & phill
posted on 5/3/05 at 09:47 PM Reply With Quote
Does OHM6015 B-A sound about right?
bob
posted on 5/3/05 at 10:35 PM Reply With Quote
That sounds like block markings to me.
The engine number is on a flatened piece of block in the position mentioned earlier,mine is two letters and five numbers and are stamped on.
The letters and numbers stamped are about 6mm in height and the flatened area is roughly about 25mm in height and 80mm long.
There might well be a pic of an engine number in a haynes manual if you have one just to give you a guide of the area to look in.
bob
posted on 5/3/05 at 10:39 PM Reply With Quote
my engine number stamped area is above the numbers you quoted earlier,as in this pic Rescued attachment MK Indy build pics 087.jpg
bob
posted on 5/3/05 at 10:40 PM Reply With Quote
you can just see the numbers in this one above the block marking numbers Rescued attachment MK Indy build pics 144.jpg
helen & phill
posted on 5/3/05 at 11:28 PM Reply With Quote
Got it!
Took a bit of uncovering had to rub off my nice new paint but got it two letters and 5 numbers.
Thanks for all the info and pics
bob
posted on 6/3/05 at 12:00 AM Reply With Quote
no problem,sometimes a bit of chalk along the numbers helps to read them
