MikeR
posted on 18/3/05 at 06:22 PM |
Exhaust Manifolds - I need one
Thats it! I've had enough.
I'm almost at the point of cutting my lolocost manifold into bits to try and make it fit and look decent (it exist half way up the side of the
chassis and i don't like that look)
What is the best way to get an exhaust manifold with decent performance?
I've got a full caterham 4-2-1 rear exit system which isn't great for performance and i'm almost at the stage where i'm going
to remake engine mounts and engine bay triangulation just to fit it........
HELP!
Jon Ison
posted on 18/3/05 at 06:25 PM |
Martin will make you a very nice custom stainless one, he as a loverly bender....
MK that is.
MikeR
posted on 18/3/05 at 06:28 PM |
yeah but thats going to cost a fortune
i'm not quite at the spending huge amount of dosh stage yet.......
but still very dejected.
Jon Ison
posted on 18/3/05 at 06:32 PM |
you may be suprised at the cost, but unless you buy or have one made its down too DIY skills,
Jon Ison
posted on 18/3/05 at 06:34 PM |
here's what u get for your money...
posted on 18/3/05 at 07:05 PM |
and it has to be said, those look damned impressive.
MikeR
posted on 18/3/05 at 07:19 PM |
what sort of price are we talking about here?
scutter
posted on 18/3/05 at 07:44 PM |
I cut my lolocost manifold to get it to fit, by using a 1mm disc in the angle grinder top and bottom leaving 10mm in the centre at the 3 and 9
o'clock positions then welding the resultant larger and smaller gaps up, you can then diegrind out any welds the project into the gas flow out of
the way.
Sorry for the lame explanation, the results are show below.
test fitting
new exhaust location
ATB Dan.
MikeR
posted on 18/3/05 at 08:44 PM |
Cheers Dan,
Your picture highlights the problem for me.
I don't want the manifold exiting half way up the side of the car. Its a very personal thing but I want my manifold exiting near the bottom
chassis rail - i just prefer that "look".
I've already cut the manifold from the header plate and think that I might be able to extend and angle the first couple of inches but then it
ends up almost touching lots of bits (engine bay side triangulation and it also comes close to the passenger bulk head and bell housing.
Don't suppose you've got a side view further back so i can see what it really looks like - hopefully I'll change my mind.
scutter
posted on 19/3/05 at 07:53 AM |
Will get one over the weekend, my exhaust clears the TR tubes by 7-10mm hopefully enough to allow any engine movement.
ATB Dan.
MikeR
posted on 19/3/05 at 11:44 AM |
i've actually removed that tube and rewelded it on the bottom rail to make it a bit lower & still with it clearing by about 5mm i'm
not happy .......... still looks in mid air!
NS Dev has probably persuaded me to make my own using stainless dairy bends.
scutter
posted on 20/3/05 at 01:30 PM |
new exhaust exit
Here's a side view Mike, sorry no exhaust but haven't the energy to fit it, circled is the upper edge of the tr tube in it's standard
position.
ATB Dan.
NS Dev
posted on 21/3/05 at 08:25 AM |
forgot to email you the link for the cheap dairy bends, so I will put it on here, that way everybody can see it!
http://www.allstainlessltd.co.uk/
MikeR
posted on 21/3/05 at 06:44 PM |
daft question - is 1.5mm by 1.5" 'man' enough for an exhaust header?
Just slightly worried that my Lolocost manifold is 2mm
NS Dev
posted on 22/3/05 at 09:23 AM |
1.5mm is plenty man enough, but if you are worried, I can get hold of thicker (dunno on price yet) from Damstahl, who do pretty much anything
stainless wise!!
I would worry about the weight of 2mm!
MikeR
posted on 22/3/05 at 06:00 PM |
aha, so i can claim this is a performance modification - going down to 1.5 mm from the lolocost 2mm exhaust........
damn, was thinking of using some of the 2mm bends + collector from the lolocost one !
