Author: Subject: Dummies guide to bike throttle bodies......
Northy
posted on 26/3/05 at 06:30 PM Reply With Quote
Hi guys, I've got these from a GSXR 1000, so what's what, and what shall I take off a bin?
Graham
Chris_R
posted on 26/3/05 at 06:32 PM Reply With Quote
no it's not.
A bit of slapstick never hurt anyone.
http://www.chris.renney.dsl.pipex.com/
Northy
posted on 26/3/05 at 06:40 PM Reply With Quote
Graham
posted on 26/3/05 at 06:42 PM Reply With Quote
Mirror image?? think you should bin the lot in my direction?? keep us posted on progress .
big_wasa
posted on 26/3/05 at 10:57 PM Reply With Quote
will be getting my bike carbs back from Bogg Brothers this week having had the full monty will post a pic
Surrey Dave
posted on 27/3/05 at 08:26 AM Reply With Quote
i could probably fit bike bodies straight on here , but its all a bit technical for me Rescued attachment Carbs On Car 6 sml2.jpg
stevebubs
posted on 27/3/05 at 11:50 AM Reply With Quote
What do I take off?
Looks like you've the double butterfly version. Unless you fancy rigging up a custom ECU to control the stepper motor on the second set, you can safely remove them plus the stepper motor - just make sure you plug the holes.
After that, it depends on which route you want to take.
If mounting direct to std DCOE manifold, you'll need to respace them and replace the fuel rail.
If using a customer manifold, just leave them as they are, make up the manifold and off you go.
HTH
Stephen
PS Changing the injectors will depend on what engine you're intending on running, but GSXR1000 injectors should be good for most car engines.
