Author: Subject: Honda Blackbird throttle pot wiring
givemethebighammer
posted on 10/7/05 at 06:39 PM Reply With Quote
Anyone got the wiring information for the above i.e. colour / positions / functions of the wires connected to the throttle pot of a carbed blackbird.
thanks
tks
posted on 10/7/05 at 09:15 PM Reply With Quote
well
it measures an sweep.....
an fast movement to compensate the ignition timeing..
one will be ground, one will be 5 or 12volts (think 5)
one will be signal..(high impadance) entrance..
tks
the ground one you find easyly to check with chasis..
the other 2 is question of enable loom
and check wich of the 2 has power...
in realyty it could work with just 2 but ok..
they can also use 3..
MikeR
posted on 10/7/05 at 09:20 PM Reply With Quote
don't suppose anyone has a spare one of these knocking around or could tell me where to get one? Mines rather broken.
givemethebighammer
posted on 12/7/05 at 10:45 PM Reply With Quote
I downloaded the cbr 1100 service manual looking at the wiring diagrams I have produced the picture below. Does it look about right ?
The G/O and Y/R wires are common to other sensors so I think they must be the ground and 5v power. The R/Y is connected directly to the ECU so must be the signal ?
[Edited on 12/7/05 by givemethebighammer] Rescued attachment blackbird TPS.JPG
