Author: Subject: Zetec in MK (Oil filter and alternator)
Chaz
posted on 3/8/05 at 04:07 PM Reply With Quote
I have just situated my engine in a rough position that it will take once fully installed.
The oil filter is rubbing against the steering column. What has everyone else with zetecs installed done/ been using? Its a Silver top.
Also i've seen different ideas of where to mount an alternator, which side, inlet or exhaust is best? Or is it personal preference?
Thanks.
stevebubs
posted on 3/8/05 at 04:13 PM Reply With Quote
filter issue - shorter filters are available. Can't remember what off, though
alternator - personal choice (i.e. where will it fit best?)
[Edited on 3/8/05 by stevebubs]
Danozeman
posted on 3/8/05 at 04:23 PM Reply With Quote
Oil filters are off a renault 5 IIRC. Nice short stubby ones.
The alt is up to you. where ever it will fit with space. The brackets are available from places.
Dan
mac1ZR
posted on 3/8/05 at 04:25 PM Reply With Quote
our engine is as far back as it will go so the oil filter just misses the steering.The alternator is of a suzuki vitari i think. Rescued attachment P1010045.JPG
zetec
posted on 3/8/05 at 05:55 PM Reply With Quote
Inlet side is best for the alternator, few ready made kits out there for around £80, forget the Tiger one as it is a bit cheap and none too cheerful. If you are doing your own mounts you maybe able to tilt the engine in up/down direction or from side to side to allow more room for a filter. Also make sure the carbs or injection sustem will not hit the top chassis tube once in place with the filter fitted.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
piddy
posted on 3/8/05 at 06:19 PM Reply With Quote
Oil filter from 1600 CVH fiesta/Escort.
About half the depth
lsdweb
posted on 3/8/05 at 07:18 PM Reply With Quote
I used a Daihatsu Charade 1.3 alternator and Tiger bracket (make your own because it's rubbish!).
See photo here
andybod
posted on 3/8/05 at 07:56 PM Reply With Quote
oil filter crossland 659 off renault 9 but can't remember which engine only about 2 inches long though fit's a treat
givemethebighammer
posted on 3/8/05 at 09:02 PM Reply With Quote
Crossland 659 / Coopers 107X / FRAM PH2874 (really short one)
Crossland 573 (slightly longer one)
coopers Z25 (longer)
Halfords 221/Champion C115 (same as above?)
Halfords 265/Champion C148 (very long - recommended part)
I use the shortest one - Crossland 659
Danozeman
posted on 4/8/05 at 07:26 AM Reply With Quote
Did i see something the other day about a daiwoo alt??
Dan
big_wasa
posted on 12/8/05 at 08:32 PM Reply With Quote
Mines renault 5 but its yet untested for clearance......
