Author: Subject: renault filter?
scutter
posted on 18/10/05 at 09:01 AM Reply With Quote
renault filter?
Hi folks,
Has anyone fitted a renault 5 oil filter to there crossflow?
If so which model did you use? as the local motor factor suggested they wouldn't fit as the threads are a diffrent type.
Many thanks Dan.
barrie sharp
posted on 18/10/05 at 10:11 AM Reply With Quote
whats wrong with the crossfow one ?
FRAPH966B £1.38 plus vat. £1.62!!
just brought one
(and head gasket kit £8.64 sump kit £6.06)
[Edited on 18/10/05 by barrie sharp]
the cars looking good" a blind man would be pleased to see it"
''stop press'' the blind mans seen it said "it felt ok"
posted on 18/10/05 at 10:25 AM Reply With Quote
Renault filter fits the 2.0 XE engine and is shorter than the Vauxhall one.
posted on 18/10/05 at 10:31 AM Reply With Quote
I use a Renault 4 filter - it's about 1.5" shorter, and allows me to remove the filter without lifting the engine!
If you can wait until tonight, I can give you a FRAM part number and a Halfords one.
[Edited on 18/10/05 by David Jenkins]
scutter
posted on 18/10/05 at 11:05 AM Reply With Quote
Thanks David, Like you I don't fancy jacking the engine everytime i change the bugger.
I can wait as the new oil pump hasn't arrived yet, stupidly i couldn't find the spring in the relief valve after it shot across the workshop
ATB Dan.
bob
posted on 18/10/05 at 11:36 AM Reply With Quote
Halfords do a real short one for a renault that will fit fords HOF 266
I think its a renault 4 up to 6/84 and also 14,15,16,17 and gourdini
MikeR
posted on 18/10/05 at 12:45 PM Reply With Quote
go on the westfield board room and do a search. I know blatters has recently posted on this subject.
(assuming its working again!)
scutter
posted on 18/10/05 at 04:34 PM Reply With Quote
Cheers all, Bob I know you already told me that but was put out by my local socalled expert in the factors.
ATB Dan.
scutter
posted on 18/10/05 at 05:13 PM Reply With Quote
My what big hands you have
Dan.
bob
posted on 18/10/05 at 05:28 PM Reply With Quote
WIX filters
posted on 18/10/05 at 07:15 PM Reply With Quote
Here we go:
FRAM PH 2874, as used on Renault R4 (950cc), R4GTL, R5L, R6 (850cc)
As originally recommended to me by Scholars, a company that tuned engines for Formula Ford.
Annoyingly, I can't find the bit of Halford's packing that I'd carefully set aside - it's somewhere in the tip that is my garage...
scutter
posted on 18/10/05 at 09:01 PM Reply With Quote
Many thanks for looking David, I'll be off to the motor factor tomorrow.
ATB Dan.
bob
posted on 18/10/05 at 09:35 PM Reply With Quote
Dan
Other makes that match up to this are
crossland 659
coopers 107x
purolator L17603
posted on 20/10/05 at 10:22 AM Reply With Quote
Late update:
Halfords HOF 238
