Author: Subject: I've got a big red one!
andyharding
posted on 28/11/05 at 09:57 AM Reply With Quote
Almost finished the cleaning/painting my engine over the weekend:-
Big Red Engine
Big Red Engine
James
posted on 28/11/05 at 10:00 AM Reply With Quote
Red or orange?
Another fine example of digital photography turning red to orange? Mine did the same!
Looks really good mate.
James
andyharding
posted on 28/11/05 at 10:07 AM Reply With Quote
It really is quite a bright red and I adjusted the white balance to make it look as close as possible to the real thing. The slightly orange hue is made worse by the tungsten lighting I think.
donut
posted on 28/11/05 at 10:33 AM Reply With Quote
Very nice mate. I have the same in black. It's a shame we have to use them as they only get dirty and miscolour.
posted on 28/11/05 at 11:00 AM Reply With Quote
that's rather smart - matches the engine stand exaclty!! did you paint the pulleys silver as well?
mookaloid
posted on 28/11/05 at 11:41 AM Reply With Quote
Proper engine
Nice job - I see you have the same problem as me though - How to clean the carb? I still don't have the answer.
Mark
flak monkey
posted on 28/11/05 at 12:38 PM Reply With Quote
Proper engine
Very nice job Andy Hope mine looks that good when its done!
Carb cleaning is a long and tedious job. You could acid clean it, using a weak solution.
Or you could do what I did with mine....
Take a small brass wire brush (you can get them from wilcos for about 50p) and some petrol. Strip the carb right down and clean it properly. Takes ages, but it does come out very shiney at the end of it all....
Heres some pics of my carb after cleaning.
http://i5.photobucket.com/albums/y197/flak_monkey/Locost%20Gallery/My%20Car/38%20DGMS%20Carb/finished3.jpg
http://i5.photobucket.com/albums/y197/flak_monkey/Locost%20Gallery/My%20Car/38%20DGMS%20Carb/finished4.jpg
Sera
http://www.motosera.com
ayoungman
posted on 28/11/05 at 02:50 PM Reply With Quote
Mines got a Silver theme
My carb was cleaned using a brass rotary brush and a Dremel polishing mop. Rescued attachment DSCF0002.JPG
"just like that !"
posted on 28/11/05 at 03:35 PM Reply With Quote
ayoungman - I've found need to report you - my eye's are bleeding!
That's a serious bit of bling!
Are you a CHAV?
RichardK
posted on 28/11/05 at 06:42 PM Reply With Quote
Never any Kleenex when you need some
Gallery updated 11/01/2011
shortie
posted on 28/11/05 at 06:55 PM Reply With Quote
Carb cleaning could probably be quite theraputic with a dremmel and a mini wire brush, should get into all the cracks and bring it up quite nice!
Rich.
gazza285
posted on 28/11/05 at 07:03 PM Reply With Quote
When I used an aerosol carb cleaner I sprayed it into the corners and it sprayed straight back into my eye. All I can say is it smarts a bit and the wife compared me to Homer until the swelling went down.
andyharding
posted on 28/11/05 at 07:05 PM Reply With Quote
WOW that's the dogs. I was going to go silver but my supplier had no silver engine paint in and I wanted to crack on.
What did it cost to get the rocker cover chromed?
With regards to the carb I will probably just buy a brand new (old stock) one. It will take me less hours working the overtime to pay for it than cleaning the old one.
Cazzy R
posted on 28/11/05 at 11:03 PM Reply With Quote
ayoungman you have very scary taste, a pink chassis indeed!
I've just been to your photo archive and see "coil in situ".
I DARE NOT LOOK!
Cazzy R
caber
posted on 28/11/05 at 11:42 PM Reply With Quote
I see you have your Pinto sideways on the engine stand. Have you tried turning it over or starting it like that?
Caber
Schrodinger
posted on 29/11/05 at 01:10 PM Reply With Quote
ISTR seeing an article a while back about cleaning carbs and it was suggested that acetone does a good job without too much effort.
regards
Keith
Suffolk
andyharding
posted on 29/11/05 at 01:24 PM Reply With Quote
I've turned it over to set the camel belt tension etc. Don't think I'd fancy starting it though
Caber
andyharding
posted on 29/11/05 at 01:26 PM Reply With Quote
I've cleaned (degreased) the carb quite well but it still looks dull.
The best degreaser you will find is White Spirit. I can't even find gloves it won't eat through but it doesn't harm oil seals etc and will melt any grease/oil. I put it in a squirty bottle and use a paint brush. Worked great on the engine.
regards
Keith
Suffolk
ayoungman
posted on 30/11/05 at 09:55 AM Reply With Quote
I'm still debating over a chromed timing belt cover. I wouldn't want to over do it !
I got the chroming done for Nowt ! Front wishbones and oil catch tank have also been Blinged
That picture is a bit old, there's a bit more polished stainless in there now !
[Edited on 30/11/05 by ayoungman]
"just like that !"
