Author: Subject: sorry - still not clear about expansion tank
posted on 21/12/05 at 09:49 AM Reply With Quote
still haven't figured out how to use an expansion tank. In a haynes manual it shows there are two pipes to an expansion tank.
As the top of my tilted radiator may be below thermostat housing, I may need to plumb in a small tank that sits in the highest position to avoid air locks.
I have spare thermostat housing with an outlet; this would go to the expansion tank.
CBS sell sealed radiator cap that I would need to fit, the expsnion tank now will have the pressurised cap.
So is my thinking correct? If so, then I need to source an expansion tank with a pressuried can and one outlet - anyone know which cars I need to look at?
thanks.
posted on 21/12/05 at 10:15 AM Reply With Quote
I used an expansion tank from an Astra (D reg) it's got 2 connections, but you could easily blank one off witha short length of hose, a bolt and some jubilee clips.
Nick
andyharding
posted on 21/12/05 at 10:21 AM Reply With Quote
Clio Mk3/4 is nice as it mounts to a flat panel with ease.
I'll try and post a pic later.
posted on 21/12/05 at 10:50 AM Reply With Quote
okey dokey; sounds like my plan is sound and blocking off excess outlets is the way to go.
now need to find the right sized/shaped tank......
RazMan
posted on 21/12/05 at 11:39 AM Reply With Quote
Are you sure you need an expansion tank? I am hoping to get by with just a header tank and bleed hose as in this diagram. Rescued attachment Water Pump diagram4.jpg
Raz
posted on 21/12/05 at 12:23 PM Reply With Quote
RazMan, maybe I am comnfusing header and expansion tank!!
In my mind I need a small thank that sits at the highest position in the water system. The system needs to be pressurised hence the cap must be a pressure type. This is a side view of what I mean - proably the same as yourswithout the heater stuff.
header tank
header tank
RM; in your case, the header tank has to have a pressure relief valve in the cap otherwise isn't there are danger something will explode?? If the tank is vented, then water is not pressuried so will boil at a lower temperature?
Is your pressure is regulated by the radiator cap; in mine case it won't be.
[Edited on 21/12/05 by 02GF74]
posted on 21/12/05 at 12:28 PM Reply With Quote
I'm with Razman on this one!
Most pressurised header tanks have at least 2 connections - a larger one that connects into the main plumbing, as in his diagram, and a smaller one that goes to the highest point in the engine's water system - the extra connection on your thermostat housing. The smaller one is there mostly to collect any air that's bubbling round the engine. Any extra small connections are for systems that need to catch any airlocks in strange places.
rgds,
posted on 21/12/05 at 12:32 PM Reply With Quote
rgds,
hmmm, so my diagram won't work? Hence I need to find another take off on the block somewhere... (there is some stuff going to the manifold but not had time to trace it round)
posted on 21/12/05 at 12:34 PM Reply With Quote
Don't worry - I went through stuff like this a while ago! If you look at this thread you'll see what I mean...
LINKY
Have a look down the page to Dave Ashurst's diagram - that just about covers it all.
BTW: you don't mention the heater plumbing anywhere - either you have a heater, or you must have a loop of pipe between the 2 places where the heater gets connected to the block. This is an ideal place to break into the circuit and fit a T-piece for the expansion tank.
cheers,
[Edited on 21/12/05 by David Jenkins]
RazMan
posted on 21/12/05 at 12:38 PM Reply With Quote
I think we are probably talking about the same thing although I am a little foggy about the terminology too.
Your diagram is practically identical to mine without the heater. If you put a 'tank' on the feed side of the pump and connect a bleed hose between the tank and rad top (or thermostat housing in your case), the whole system should be self bleeding.
*edit* Yes, my cap is a pressure cap rated at 15psi iirc. I was under the impression that a pressurised system was the best way to go - but I havent got the foggiest idea really so I just listen to advice and go with the options that make the most sense. It's a steep learning curve when building a car isn't it?
[Edited on 21-12-05 by RazMan]
Raz
smart51
posted on 21/12/05 at 12:57 PM Reply With Quote
I have two pipes on my header tank, one from the thermostat on the top of the engine to the top of the tank. This is for air to escape. One from the water pump to the bottom of the tank, this is to put water into the system to make up for expelled air (or water leaks!)
With one pipe, you are hoping for air to go in one direction and water in the other.
posted on 21/12/05 at 01:32 PM Reply With Quote
yeah ... been thinking about this whilst out running...
it's gotta due with the water expanding/contracting when heated/cooled and in particular when the thermostat is closed. You don't want to build up pressure in the block nor hoses etc: and likewise don't want low pressure when cooling down as water will being to boil.
To get round that, a small hole in the thermostat to allow flow should sort it out? But there's more to it than that I'm sure.... now need to eat then read up about it.
posted on 21/12/05 at 01:35 PM Reply With Quote
When the thermostat is closed, the water will circulate round the heater circuit - it's never shut off, unlike the main radiator circuit - that's why I said that you either need a heater, or a piece of hose to replace it.
RazMan
posted on 21/12/05 at 01:52 PM Reply With Quote
Even with a heater in circuit you still need the flow though a closed thermostat - what if the heater valve is switched off?There is always some flow through a closed thermostat but as 02GF74 says you can always drill an extra hole in it to increase it if needed.
Raz
posted on 21/12/05 at 02:07 PM Reply With Quote
what is difference between my first picture and this one?
header tank/rad
header tank/rad
you can look at this as the tank being part of the conventional radiator albeit the hose to it is much smaller.
Note in my pic I am using the thermostat take of as an extension of the main cooling system so it remains full rather than an air bleed.
.... I realise this piccy ^^^ there is potential for air locks, but let's ignore those for now.
posted on 21/12/05 at 02:19 PM Reply With Quote
Got a tee piece from a ford in a breakers yard that fitted nicely. Can't remember which Ford though
posted on 21/12/05 at 03:07 PM Reply With Quote
Have another look at Dave Ashcroft's drawing on the other thread - this matches just about every car out there that has a pressurised header tank. Any attempt to cut corners will either not work, not work very well, and/or simply give you no end of problems.
Why not just do it properly?
posted on 21/12/05 at 03:17 PM Reply With Quote
I know exactl what you are saying; if my method was better, then car manufacturers would use it since it is cheaper.
All I am trying to get is a reason why it won't work. Because everyone else uses another method is not good enough reason since this does not explain why.
timf
posted on 21/12/05 at 03:30 PM Reply With Quote
if you try to fill a closed loop system with only one hose connection though a small bore hose you will be there all day cause the air has no where to go but up the same hole that you are trying to pour water down
try filling an empy bottle ysung a funnel that is jammed in the opening and you'll se what i mean
posted on 21/12/05 at 03:43 PM Reply With Quote
ok, but filling it up is a one time task so is that really a problem?
There has to be something more fundamental; I have a feeling maybe the small bore tube, 8mm will give problems with water flow when thermostat first opens or something like that?
posted on 21/12/05 at 05:51 PM Reply With Quote
There's nothing complicated - it's just that a car's cooling system is full of places that can trap air. These air locks will stop the water circulating properly, unless there is somewhere for them to escape - hence the vent in the 'stat cover that lets it go out to the airspace in the header tank.
Marcus
posted on 22/12/05 at 11:53 AM Reply With Quote
If you order an original equipment thermostat from either Ford or Burtons, it comes with a small hole in it to allow for a small flow even when closed.
I have no header tank and have had no problems in a 2 hour traffic jam in St. Tropez earlier this year (nearly boiled my head though!). The fact that the thermostat may look dry when the engine is cold doesn't matter, as the water is pumped upwards through the 'stat when the engine is running.
Marcus
Marcus
Because kits are for girls!!
posted on 22/12/05 at 12:06 PM Reply With Quote
yep; same is true for rover v8 thermostat; dunno why after market ones don't have this.
thermostat may well be dry since the water will cntract when cooled.
is you rad. a sealed unit or has a cap? And does it sit lowert han the thermostat?
posted on 22/12/05 at 01:22 PM Reply With Quote
The little hole in the thermostat is to let air through, not water! Otherwise any air would get trapped under the thermostat, which stops the water touching the 'stat wax capsule, and the stat will never open. Guess how I know?
And as someone said earlier, you must have some connection between the manifold outlet and the water pump (the heater circuit), otherwise no water will circulate when the 'stat is closed.
BTW: the thermostat should NEVER be dry, even when the engine's cold, if your coolant system is set up properly. I use an unpressurised overflow tank, which receives the surplus water when the engine's hot, and the surplus is sucked back as the engine cools. This is the old-fashioned system that was used in the original Escort.
[Edited on 22/12/05 by David Jenkins]
