Author: Subject: Micra Radiator
paulbeyer
posted on 27/3/03 at 10:27 PM Reply With Quote
Micra Radiator
I'm meeting up with a guy on Saturday that has a Micra Rad for sale. Can someone let me know what the dimensions are so I can verify it is from MK1 Micra and not a Massey Furguson or summat. Or better still post a piccie of one or point out some distinguising features so I can verify it is the real thing.
Cheers lots.
7 out of 10 people suffer with hemorrhoids. Does that mean the other 3 enjoy them?
Mark Allanson
posted on 27/3/03 at 10:45 PM Reply With Quote
I am also considering a Micra radiator, but I am still struggling to believe that a rad designed to cool 40BHP is going to cope with a 125BHP engine being used the way nature intended in a locost
Is there any reassurance out there?
Mark
stephen_gusterson
posted on 27/3/03 at 11:43 PM Reply With Quote
i agree
however, the capacity of a rad is to do with surface area and air velocity and temp.
so, if you can put ballistic amounts of air through it......still seems a tall order tho.....
atb
steve
D Beddows
posted on 28/3/03 at 01:20 AM Reply With Quote
Sorry,can't help with the dimensions of a Micra radiator - but I'm betting it's lightweight aluminium finned thing which should do nicely. I've used MK1/2 Golf radiators in the past and they far out perform any Ford type nonsence - the surface area of a radiator has nothing to do with its external dimensions after all.
Mind you my fathers' car toy is a properly sorted Plus 8 Morgan and from choice I wouldn't use the radiator in that to cool a Micra - but it works now in his car....how you get the air through a radiator is the most important thing and a header tank works wonders btw
Dave
zetec
posted on 28/3/03 at 08:46 AM Reply With Quote
I've fitted a MK2 Polo rad and had the engine ticking over with bonnet fitted for 15-20 mins and no problems yet. I was told this rad has been used for racing for years and is standard fit on W**tfield (pay £40 new rather than £130 W**tfield!). Other benifit is ali core means warm up time is 3-4 mins, suspect Micra similar design so should be fine.
Mark Allanson
posted on 28/3/03 at 10:22 PM Reply With Quote
Shit or bust, I'll get one tomorrow!
RoadkillUK
posted on 28/3/03 at 10:24 PM Reply With Quote
I have just fitted a Micra Rad to my Chassis but it's miles away atm and I won't be visiting until Sunday but I do have pics on my website
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
Mark Allanson
posted on 28/3/03 at 10:52 PM Reply With Quote
I like the McLaren F1 driving position1
RoadkillUK
posted on 29/3/03 at 02:31 AM Reply With Quote
Yeah, it's er just resting, I was considering it but I think the gearlever might get in the way
Roadkill - Lee
www.bradford7.co.uk
Mark Allanson
posted on 29/3/03 at 01:32 PM Reply With Quote
back to the original thread(!)
A pickie of the micra rad I got this morning for £5. I had to get 2, I accidently licked the first one and stuck it on an envelope! Rescued attachment DCP_0665sml.jpg
MK9R
posted on 29/3/03 at 06:28 PM Reply With Quote
thats the same as mine, but the car isn't running yet to can't comment on cooling capabilities
Edited to say - and not using a pinto. I'll get my coat :p
[Edited on 29/3/03 by MK9R]
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
Northy
posted on 29/3/03 at 07:55 PM Reply With Quote
I looked at a Micra rad at the scrappers this morning. Are they all Ali? It didn't look it. The car had been stuffed at the front, so didn't want it anyway.
I do happen to have a Fiat Uno rad lying around that I've been looking at, its nearly all plastic, and is very light! Any thoughts?
Graham
posted on 6/4/03 at 03:25 PM Reply With Quote
I've just got a new nose cone (from Triton) and found that my Mk2 Escort radiator doesn't fit!
I don't want to hack the new plastic around (it's far too nice!) so I need to get a smaller rad. The favourites seem to be the Mk2 Polo or the Micra rads.
Anyone used either of these in in a road-going car? I'm running a mildly tuned 1660 X-flow, which shouldn't be too demanding, but I'd like to know whether they are up to the task.
cheers,
BTW: I can only reinforce what Jasper has said the past - Triton GRP is excellent - well made, solid (1/4" thick in places!), beautiful finish, and easy to fit.
Dave Ashurst
posted on 6/4/03 at 05:45 PM Reply With Quote
My micra rad seems fine* and comes with sucking fan operated by a thermoswitch in the radiator.
I replaced my escort radiator earlier this year because the engine tended to overheat in stop-start traffic.
regards
Dave
*Well so far so good anyway, cold weather daily running on a 1700 crossflow, kent 234 cam, high flow head, two dcoe 40s, moderate compression and with a standard 88 deg.C thermostat in dome type housing vented to a pressurised header tank with min coolant level above the top of the highest pipes.
Fifer
posted on 7/4/03 at 02:09 PM Reply With Quote
Does anyone actually have the dimensions of the Polo rad ? and the Micra rad ?
Just a simple A x B x C would do I guess !
Rob Lane
posted on 7/4/03 at 02:56 PM Reply With Quote
Lee,
The Micra rad looks as if it will do the job. The newer ali rads are far more efficient than the older copper xflow items.
It certainly fills the nosecone nicely, just make sure that the filler is the highest point above engine.
On subject of nosecone, I notice from photos that you are holding nosecone on with couple of inside handscrews and at bottom by two fastenings screwed in.
You will certainly need to remove the nosecone many times and with that in mind may I suggest using 'Zeus' fasteners.
I've used one underneath and one each side of nosecone on rebated flange where bonnet fits, down at side rail. They do not sick out proud other than rivet height and are cheap, quick and easy to use.
Rob Lane
posted on 7/4/03 at 03:07 PM Reply With Quote
Lee/Dave,
What model Micra did your radiator come from?
There's quite a few models to be found!
cheers,
[Edited on 7/4/03 by David Jenkins]
James
posted on 7/4/03 at 03:32 PM Reply With Quote
Originally posted by David Jenkins
Lee/Dave,
cheers,
I think they're all pretty similar.
I think there's 4 models of Micra including the one that just came out (last couple of months). Assuming there are 4 kinds you want the MK2 type!
There were two of the wanted ones at my scrappie they were both of 'E' and 'F' reg vintage!
Hope that helps!
James
Fast Westie
posted on 8/4/03 at 09:24 AM Reply With Quote
You guys should also look at the Polo rad thread
The car in front is a Westfield
bob
posted on 8/4/03 at 09:41 AM Reply With Quote
The rad i found for jasper came from a D reg micra 1 litre,its exactly the same as marks pic.
Mark Allanson
posted on 8/4/03 at 09:07 PM Reply With Quote
Fitted the rad now, next small problem, the pinto hoses are this big (..................) and the micra ones are this big (......).
I think an intermediate metal pipe welded to fit both sizes would work, but I am sure there is a better way - anyone know what it is?
[Edited on 8/4/03 by Mark Allanson] Rescued attachment DCP_0717sml.jpg
stephen_gusterson
posted on 8/4/03 at 09:32 PM Reply With Quote
pretty sure I have seen flashy and expensive hoses with different diameters each end.....
europa, for instance, do a straight adaptor hose goig from 45 to 25mm dia (example) for about 9 quid.
what sizes are you looking at......if you dont have a catalog I can tell you a part no.
atb
steve
MK9R
posted on 9/4/03 at 06:41 AM Reply With Quote
Samco do loads of different size hose's and reduction bits Expensive, but look very nice!
samaco
[Edited on 9/4/03 by MK9R]
Cheers Austen
RGB car number 9
www.trackace.co.uk
