Author: Subject: Bike carb fueling.
Danozeman
posted on 22/4/06 at 05:09 PM Reply With Quote
Bike carb fueling.
I have a set of ZX9r carbs.
Im guessing the fuel goes in the small pipe and the fatter one is the overflow?
Also the smaller bore one goes straight through so do i block off one end or what?
I know pics would help but cant get any at the min.
Many thanks
[Edited on 22/4/06 by Danozeman]
Dan
posted on 22/4/06 at 05:21 PM Reply With Quote
fuel goes in the underside, theres usually a tee connected up, but if its gone you are looking for a small 8mm nozzle between each pair. Ive left the top ones alone.
jacko
posted on 22/4/06 at 08:14 PM Reply With Quote
Hi on E models the fuel pipe is a 10mm pipe under the carbs in the midle . the small pipes are water pipes
Jacko
Danozeman
posted on 23/4/06 at 10:58 AM Reply With Quote
Right heres a piccie.
These are the carbs
carbs
carbs
Dan
Danozeman
posted on 23/4/06 at 10:59 AM Reply With Quote
Iv put fuel in the bottom. it seems to be fueling now just got to get the megajolt sorted out and it should run hopefully.
I want it started today.
Dan
