Author: Subject: Clutch cable?
Bob da builder
posted on 25/4/02 at 02:51 PM Reply With Quote
Clutch cable?
Hey,
What clutch cable have you all used?
i have a MK escort chassis with MK peadles, escort box, the escort cable is too short so the radius of the cable is so dam tight that it will wear in no time, have tried a sierria cable the outter is perfect but the inner cable is 100mm to long???
i have been given ways to shorten the cable but i would perfere to use a stock item to make future replacements easy when the AA come out!!
Any ideas?
Bob
jmbillings
posted on 25/4/02 at 03:16 PM Reply With Quote
Not tried it, but was gonna use a Capri one- looked like it had the same ends as the 'scrote one but was a bit longer... Anyone confirm?
Marcus
posted on 25/4/02 at 09:08 PM Reply With Quote
Bob, did you check out Locodudes car at Stafford? He has used an Escort cable in a 'U' shape with some stupidly narrow angle. I thought it would never work like that but it's been on the road for nearly a year with no problems. Smooth as you like aswell.
Marcus
Bob da builder
posted on 27/4/02 at 08:17 PM Reply With Quote
I have decided to drill out an original serria cable and shorten it by 90mm, then re-soldered the cable and sofar it has held the pressure.....well for 1 day!!! see what the road test dose!?
bob
