Author: Subject: 2.0 Zetec Plumbing
Krismc
posted on 25/6/06 at 07:59 PM Reply With Quote
2.0 Zetec Plumbing
Right my set is as below on my black top zetec, i have the 2 rad connections the water pump connection, the main water rail connection(above thermo), my top and bottom expansion tank connections, as what looks to be a hole in side of waterrail which could be utilised if needed!
basically what goes where!!!!????
[Edited on 25/6/06 by Krismc]
Krismc
posted on 25/6/06 at 08:07 PM Reply With Quote
andyharding
posted on 25/6/06 at 08:24 PM Reply With Quote
I'd do it like this assuming the small take-off on the water rail is the highest point and before the thermostat.
Zetec Plumbing
Zetec Plumbing
Krismc
posted on 25/6/06 at 08:26 PM Reply With Quote
it aint the highest point its nearly the highest point the thermostat and rail outlet is over a inch higher!
and how high does the expansion tank have to be???
andyharding
posted on 25/6/06 at 08:30 PM Reply With Quote
That should be OK.
The top of the expansion tank needs to be the highest point on the whole system at a minimum.
[Edited on 25/6/06 by andyharding]
Krismc
posted on 25/6/06 at 08:47 PM Reply With Quote
so the water pump takes water from expansion tank and from the bottom radiator hose!!
andyharding
posted on 25/6/06 at 08:54 PM Reply With Quote
Yup, the top hose on the expansion tank should only be about 8mm though. This bleeds out air and lets the whole system come up to temp and then when the stat opens the much bigger hoses through the rad are less restrictive.
andyharding
posted on 25/6/06 at 08:56 PM Reply With Quote
Just to add I haven't had a Zetec running like this but have done over 1K miles on my Pinto plumbed almost like this and it's worked very well.
stevebubs
posted on 26/6/06 at 07:49 AM Reply With Quote
Zetec Plumbing
Zetec Plumbing
This looks fine but I think most people drill a 3mm hole in the thermostat for warmup circulation
andyharding
posted on 26/6/06 at 08:07 AM Reply With Quote
That sounds like a good idea as the small take-off on the manifold is quite a way from the stat.
roadboy
posted on 26/6/06 at 09:08 AM Reply With Quote
The plumbing is correct, make sure the hose from the expansion tank to the bottom hose isn't too largeas the pumpwill pull the water down from the tank.
Ian
Jude Performance Services
stevebubs
posted on 26/6/06 at 04:54 PM Reply With Quote
Don't think there's really a set size. However, you do need to be careful as to the pressure cap fitted either on the rail or the header tank (one only remember). I think the zetec cooling system likes to run at a slightly higher pressure to most road cars.
I fitted an expansion tank like the one from Westfield to my car, but one from any zetec-engined car will do...
Krismc
posted on 26/6/06 at 06:20 PM Reply With Quote
Ive got a MNR Alli tank to be fitted, and ive already got a 3mm hole in the thermostat, but ill plumb in as you say!!
And tell you the results!
stevebubs
posted on 26/6/06 at 10:56 PM Reply With Quote
FWIW,
I've only just come back from Le Mans....pretty intense heat (35deg+)... and cooling system didn't skip a beat.
Did fit the reverse impellor before I went, though...
http://boardroom.wscc.co.uk/cgi-bin/ikonboard.cgi?act=ST;f=3;t= 32834;hl=stevebubs
