Author: Subject: Gear lever extension
givemethebighammer
posted on 13/8/06 at 10:29 AM Reply With Quote
I have been using a Westfield gear lever extension for a while now and to be honest the change is not as good as it could be. I have looked at modifying to connect the extension rod directly to the selector shaft with a roll pin but I don't have access to a lathe on a regular basis. Then I thought about just welding a lever in parallel to the standard one like the picture below. Any reason why it wouldn't work ? The lever won't be any higher in the tunnel than it was. Will it affect the throw etc ?
[Edited on 13/8/06 by givemethebighammer] Rescued attachment gearstick.JPG
mookaloid
posted on 13/8/06 at 10:33 AM Reply With Quote
you will be effectively making the lever longer which will increase the throw.
However you can get some (if not all) of this back by making yourself a quick shift as in Dave Andrews article:
http://hometown.aol.com/dvandrews/quick.htm
But I have a feeling you have already seen this........
Schrodinger
posted on 13/8/06 at 11:14 AM Reply With Quote
You will probably have difficulty in selecting reverse.
Dusty
posted on 13/8/06 at 11:46 AM Reply With Quote
I butchered this one a while back to allow a 3 inch move forward of the box. Then converted another spare gear lever by bending the shaft using oxyacetoline and and did Dave Andrews quick shift mod. Still OK for getting reverse but much more bend and it would get difficult. Rescued attachment sticks1.jpg
posted on 13/8/06 at 12:11 PM Reply With Quote
Check out the remote gear lever set up on David Jenkins site . Precise gearchange with quickshift , correct reverse stop , reversing lights work correctly and locost. Mine cost just 92p Would put in link if I knew how
ruudbeckers
posted on 13/8/06 at 02:57 PM Reply With Quote
Linky
posted on 13/8/06 at 03:55 PM Reply With Quote
Thats the one , thank you.
givemethebighammer
posted on 13/8/06 at 07:33 PM Reply With Quote
thanks for the replies
I hadn't thought about the reverse thing. I think the way to go is probably modifying the westfield remote to match the way David Jenkins attaches his gear selector (with roll pins). But like I said I don't have regular access to a lathe, however I know a local bloke with one who may help.
thanks again
