Author: Subject: Radiator Position
RichardK
posted on 28/10/06 at 07:36 PM Reply With Quote
Radiator Position
Is it ok to mount my polo rad verticaly, ie with the inlet and outlet at the top or is this a no no. Where I have it at the moment the bottom hose connector clashes with tube LB.
1.So can I mount it verticaly?
2. Mount it the right way up but further back and put in an S bend in the bottom hose.
If 2. what is the distance of the rad from LD
As you can probably tell I haven't got a nose cone yet so would it be better to wait and bugga about when I have one
Look forward to hearing your feedback.
Ta
Rich
JackNco
posted on 28/10/06 at 09:50 PM Reply With Quote
personally i have no idea. but i would have thought it would be better to have the outlet on the bottom...
John
Some people are worried about the difference between right and wrong. I'm worried about the difference between wrong and fun.
O'Rourke, P.J. (1989), Holidays in hell. London (Picador)
Stu16v
posted on 28/10/06 at 10:19 PM Reply With Quote
Hang fire till you get your nosecone. The Polo rad can be a tight fit in soem nose cones at the best of times...
flak monkey
posted on 29/10/06 at 08:41 AM Reply With Quote
The polo rad is a damn tight fit in the nose cone. I mounted mine at an angle to allow a pipe to be fitted to the bottom. I used a top hose from a bubble shaped rover 400. this has a tight bend which will let the bottom hose clear the chassis tubes.
Sera
http://www.motosera.com
omega 24 v6
posted on 29/10/06 at 11:22 AM Reply With Quote
As said by others it's a tight fit and you've come across the exact same problems as me with the 442. I did get around it by offsetting slightly to the drivers side and lifting it up to the top of the nosecone. So yes I'd wait until you've got your nosecone (Nearly time to ask santa for one)
