Author: Subject: MT75 mounting
timex
posted on 7/11/06 at 08:43 PM Reply With Quote
MT75 mounting
Has anybody please got any pictures of there MT75 mounting brackets. mine has way too much movment in it?
Dusty
posted on 7/11/06 at 11:01 PM Reply With Quote
I would suggest you order from Westfield. Similar to the ford ones but overdosed on viagra. Pic here.
[Edited on 7/11/06 by Dusty]
nludkin
posted on 8/11/06 at 08:58 AM Reply With Quote
The ones from westfield are essentially 2 bobbins screwed into the underside of the MT75.. So, they would also give a fair bit of movement?
I will try and get some pictures of my setup for you later today.
The pic on the westfield site is the mounting for the Type 9 box apparently.. They don't have a picture of the MT75 one.
[Edited on 8/11/06 by nludkin]
nludkin
posted on 8/11/06 at 09:23 AM Reply With Quote
MT75 Mounting - Westfield
Dusty
posted on 8/11/06 at 10:46 AM Reply With Quote
Whoops. Shows I'm a type 9 user. Shouldn't believe things I see in the westfield shop. Sorry.
zetec
posted on 8/11/06 at 03:09 PM Reply With Quote
I mounted a plate on the chassis plates using 4 Mini exhaust bobbin rubbers then used the single large bolt that screws into the centre of the gearbox mounting to fix thru the plate.
