Author: Subject: Which pipe to tank, which to carbs ?
andyace
posted on 21/7/07 at 03:46 PM Reply With Quote
Sorry,
Hopefully an easy question, ZX9R carbs, which pipe to the tank which to the carbs.
Also is it ok for this to sit higer than the tank?
ZX9r Fuel Pump
ZX9r Fuel Pump
posted on 21/7/07 at 03:55 PM Reply With Quote
Normally the filter goes after the pump.... so your guess looks right. To be honest I'd just fit it- if it's the wrong way round just swap the pipes over
Normally having the pump above the tank isn't a problem.....
Marlon
posted on 21/7/07 at 04:02 PM Reply With Quote
I think you have it right in your pic but doesn't it say on the top of the pump where the pipes come out? Its probably not the same but the zx6 one i've just bought does.
john
Band Anyone?
Linky to SWMBO 's band
Linky to Brother in laws band
MKoc 1081
mackei23b
posted on 21/7/07 at 04:10 PM Reply With Quote
Hi there
I think the pump should be marked for the outlet 'o' or 'i' for inlet next to one of the pipes.
Ian
posted on 21/7/07 at 04:55 PM Reply With Quote
The filter is on the line from the tank
and the 'T' goes to the carbs, one feed to each pair
posted on 21/7/07 at 05:07 PM Reply With Quote
Think the pipe you have marked as outlet is in fact the inlet looking at the way the fuel filter is fitted. May be worth checking for an arrow on the filter?
posted on 21/7/07 at 05:08 PM Reply With Quote
Quicky pikky
andyace
posted on 21/7/07 at 06:27 PM Reply With Quote
I am guessing that the pipe with filter does actually come from the tank as its only 8 inchs or so, whereas the other pipes with the t piece have been cut.
Also I guess you would want to filter crap out before sending it into the pump.
At the end of the day you are correct its only a matter of switching the pipes around if its wrong.
Thanks all for your help.
