Author: Subject: Fury V8, help identify this hydraulic clutch
Alez
posted on 11/10/07 at 05:52 PM Reply With Quote
Sorry, don't even know the name for this particular bit in English
Fury V8 again.
I hope that the pic is good enough.
It's leaking and as a consequence the clutch pedal has lost some travel and now the clutch doesn't disengage 100%. Because of this, I can't select 1st or 2nd gears with engine started, 3rd is fine although the idle rpms decrease just a bit (engine trying to pull car). No way I could try reverse.
So I have a few questions for you today
What is that exactly so I can order a replacement?
Now, the clutch is a rather heavy one, the guy I bought the car from told me that he thinks he fitted a too heavy clutch, from the car advert that's: "Mclaud billet machined flywheel and uprated clutch (New standard AP clutch slipped and was replaced due to torque of new engine)".
The fact that it's a heavy thing to move, may that have to do with the failure? Do these bits stress or are they pretty sturdy? Is that maybe just normal ageing? Would you consider upgrading to a bigger thing, do they exist?
Finally, the garage that will replace that is a normal place, i.e. not happy to adapt a different bit, they are happy only to replace the failed one for another which is mechanically compatible. What do you think, buy a new one, same type, job done? Or should I expect future trouble, then best to look for a special garage?
Thanks a lot.
designer
posted on 11/10/07 at 05:53 PM Reply With Quote
It's the hydraulic clutch slave cylinder.
Agriv8
posted on 11/10/07 at 06:03 PM Reply With Quote
i would say its one of these.
slave from an SD1.
Regards
Agriv8
mr henderson
posted on 11/10/07 at 06:04 PM Reply With Quote
Slave cylinder from Rover SD1 V8 or TR7V8 should do nicely. Sort of thing any motor factors might have, otherwise Rimmer Bros will be able to supply.
mr henderson
posted on 11/10/07 at 06:05 PM Reply With Quote
My typing is too slow, and there no way I could draw that quickly!
Agriv8
posted on 11/10/07 at 06:17 PM Reply With Quote
Oh ps should be able to get one for £20 / 30 in the uk.
You can get reseal kit looking at the outside of the unit I would not bother going down this route.
We used to get though quit a few of these on the v8 buggy due to driver abuse.
regards
Agriv8
Alez
posted on 11/10/07 at 06:18 PM Reply With Quote
OK guys, what can I say? Thanks so much for what looks like one less to worry about quite soon.
Danozeman
posted on 11/10/07 at 08:19 PM Reply With Quote
looks like on off an ldv 200/pilot aswell. You can get rebuild kits or another one quite easily.
Dan
posted on 11/10/07 at 08:22 PM Reply With Quote
Looks as if the pipe fitting has been "modified"
Alez
posted on 11/10/07 at 09:18 PM Reply With Quote
As in "hit and subsequently damaged"?
ed_crouch
posted on 11/10/07 at 09:33 PM Reply With Quote
Also looks like someone has had the release lever fall orff, then cut a hoel to put it back on again without separating engine and box...
The Wedge boyos do it as you have to remove the engine to get the box off in a Wedge.
Seems like a bodge to me: id heave the lump out and do some blingery...
Ed.
I-iii-iii-iii-ts ME!
Hurrah.
www.wings-and-wheels.net
Alez
posted on 12/10/07 at 02:17 PM Reply With Quote
Ed.
Sorry I'm confused now Do I need to remove the engine from the bay to replace that slave cylinder?? Sorry my English is as poor as my car skills.
[Edited on 12/10/07 by Alez]
Alez
posted on 12/10/07 at 02:22 PM Reply With Quote
Sorry, also when you say SD1 does that mean I can tell the guy to get the slave cylinder of any eighties Land Rover V8? People here tend to ask "what's the car and what year is it" when you want a replacement, rather than what's the engine or whatever else so if you don't have a car model and a year that's a problem.
Thanks for all your patience.
posted on 12/10/07 at 05:57 PM Reply With Quote
Not damaged but it comes out of the slave cylinder there appears to be some braze where someone has made a fitting?
