Author: Subject: 4age plumbing
RichB
posted on 20/12/07 at 01:18 PM Reply With Quote
4age plumbing
Hi guys
After finally sourcing an engine (4age 20v blacktop) I'm starting the joy of planning the plumbing. I found this photo for reference (as well as peoples archives, thx ) but wondered if I could check a few things.
1. The diagram shows the 'Heater Lines' with a 'don't loop' comment but they are loopedint the piccy!? I presume these go to/from a plumbed in heater but which way round should they be?
2. I won't be using the brake boost lines or the AC line, so can I just cap them off?
3. What are the PS(1) and PS(2) lines?
bigrich
posted on 20/12/07 at 05:38 PM Reply With Quote
PS= power steering hoses perhaps
Mark G
posted on 20/12/07 at 07:21 PM Reply With Quote
don't know if it'll help you atall but there's loads of 4AGE information on the link below.
Good luck
http://home.clear.net.nz/pages/phil.bradshaw/4AGE%20into%20RWD.htm
RichB
posted on 20/12/07 at 08:29 PM Reply With Quote
Thanks, I've spent quite a while trawling t'internet but have yet to find an idiots to what goes where.
R1 STRIKER
posted on 21/12/07 at 12:58 AM Reply With Quote
What ecu you using?
Ben.
thomas4age
posted on 21/12/07 at 11:49 AM Reply With Quote
Here you go,
works a treat like this from +33degrees to -7 degrees,
temp always stays 86degrees when in motion, never overheated in 14.000kms+
Rad is from an MG, I think it looks like one)
the statement about the heater lines in you picture is WRONG, you'll get a hotspot in the head. the toyota levin has a 3 way valve for heater controll, so the line allways flows coolant even with the heater turned to cold.
4age 20v coolant 2
4age 20v coolant 2
4age 20v coolant
4age 20v coolant
Good luck gimme a shout if you have questions.
Grtz Thomas
PS Hey Ben, how are you doing with the striker?
[Edited on 21/12/07 by thomas4age]
If Lucas made guns, Wars wouldn't start either.
RichB
posted on 21/12/07 at 12:57 PM Reply With Quote
Ben, I am looking to use the stock ecu.
Thomas, thanks for those piccies. I'd been looking at your archive trying to figure out the routing.
bimbleuk
posted on 22/12/07 at 05:31 AM Reply With Quote
Very similar routing on my car except I recently installed a water/oil cooler. So on mine the heater loop goes to and from the oil cooler sat between the oil filter and engine block. The header tank is T'd into the top heater hose similar to above.
As for the vacuum hoses as I'm using an OMEX ECU I've basically blocked them all. Except one going to a MAP sensor and another going to my boost gauge (as its got an SC installed).
Here's a decent guide to the various connectors..
http://www.my-acoustic.com/Car/vacuum/4_throttles'_vacuum/4_throttles'_vacuum.htm
bimbleuk
posted on 22/12/07 at 05:39 AM Reply With Quote
Another picture for ya
Silvertop 4AGE 20V, coolant plumbing
[Edited on 22/12/07 by bimbleuk]
