Author: Subject: Xflow valve oil seals with double springs
UncleFista
posted on 6/11/03 at 09:21 PM Reply With Quote
Hi, the valve oil seals I have that came with a top-end gasket set are too large for my head
The inner springs take up the space usually reserved for the seals, I have a photo showing the standard seal (large) and the old seals (that fit)(small one) IMAGE HERE
Can anyone tell me what I need to order or would it be best to go to my local engineering place and ask them ?
Cheers in advance
Tony Bond / UncleFista
david walker
posted on 6/11/03 at 10:07 PM Reply With Quote
You should use 1275 mini stem seals with the double spring assembly.
Dave Walker, Race Engine Services - 07957 454659 or 01636 671277
UncleFista
posted on 6/11/03 at 11:00 PM Reply With Quote
Cheers again David, you're a real mine of information
UncleFista
posted on 7/11/03 at 04:25 PM Reply With Quote
just to reply, got some valve seals for a 1275 A series from my local engineering place no problem.
Also got new piston rings, set of main bearing shells, new crank thrust washers and a bottom-end gasket set. Got the lot for £90
Friday afternoon and my patented "I don't need a receipt (wink)" speech and everything became much cheaper with no VAT either
Chuffed.
darren(SA)
posted on 8/11/03 at 03:44 PM Reply With Quote
Just for interest sake, what double valve springs can you use from an existing car?
I bought Kent ones for around R500 from a performance shop here in SA. (imported from UK)
cheers
darren
