Author: Subject: Cortina axle ratio
mackie
posted on 15/12/03 at 12:35 PM Reply With Quote
Cortina axle ratio
Can anyone tell me what the axle ratio for a MK5 2.0l GL Cortina is?
Mackie.
StuartA
posted on 15/12/03 at 12:51 PM Reply With Quote
There should be a little metal tag on the rear cover (it is held on using one of the bolts). Should have ratio on it. If not I would suspect 3.89, but may stand corrected.
Other alternative is to rotate drive shaft and see how many times the wheel spins... not as accurate but should give you a good idea.
