Author: Subject: 16v redtop
frankycopp
posted on 24/8/08 at 01:30 PM Reply With Quote
16v redtop
theres a 16v redtop for sale local having trouble finding a x-flow so how hard is it to fit the 16v have a type9 box what parts will i need and is it worth it? thanks
Paul TigerB6
posted on 24/8/08 at 02:48 PM Reply With Quote
Great engine. Should give plenty of power (170 - 180bhp or so). You will need a bellhousing though to convert it for use with a type 9 gearbox.
like this one that has been on ebay previously
Well worth it if you can get the bits you need. First se7en i went out in was a Westfield with this engine back in 1999
Have a look through the SBD website for more info
linky
[Edited on 24/8/08 by Paul TigerB6]
Steve Lovelock
posted on 25/8/08 at 12:19 PM Reply With Quote
I have an XE in my Leugo and the car is beautiful to drive, I'd recommend one anyday. The set up does cost a bit but I'd say it is worthwhile. The main expense was on:
clutch ~ £250
sump ~ £100
gearbox adapter ~ £150
other than that you'll need to sort out the fueling and timing but that will cost the same for whatever engine you use.
The engines are cheap though.
Good luck
bill132hotrod
posted on 25/8/08 at 01:37 PM Reply With Quote
xe engine
I have got the XE engine as well they are almost bullet proof, and loads of grunt heres mine:-)
PERSEVERANCE is the word of the week. Stick with it the results are SWEET.
martyn_16v
posted on 25/8/08 at 02:51 PM Reply With Quote
Originally posted by Steve Lovelock
clutch ~ £250
Is that a hydraulic setup? All i've had to buy is a friction plate and a clutch arm (and a cable, but haven't got that far yet), not much over £50.
Steve Lovelock
posted on 25/8/08 at 03:49 PM Reply With Quote
I can't remember (ie don't want to) exactly how much it was but because the plate, cover and bearing were from 3 different cars it worked out very costly.
NS Dev
posted on 26/8/08 at 08:44 PM Reply With Quote
here's mine:
exhaust 2
exhaust 2
can't argue with 200hp with no internal mods.
