Author: Subject: Which way in / out ?
andyace
posted on 6/9/08 at 10:04 PM Reply With Quote
Hello thanks in advance, hopefully an easy one. Could anyone tell me which pipe is in and which one is out? A or B
This is a ZX9R E fuel pump.
Many thanks, Andy
LBMEFM
posted on 6/9/08 at 10:22 PM Reply With Quote
Connect it to a battery and see which pipe sucks and which one blows.
Barry
posted on 6/9/08 at 10:33 PM Reply With Quote
Attach it, if when you switch the ignition on you hear a bubbling sound from the fuel tank swap the pipes over on the pump
That's what I did anyway
YQUSTA
posted on 7/9/08 at 07:37 AM Reply With Quote
Mine is the same (but a c1) and as said A is the in and B the out
YQUSTA
Avoneer
posted on 7/9/08 at 08:16 AM Reply With Quote
Fuel filter side is generally in - to protect the pump.
Pat...
posted on 7/9/08 at 12:52 PM Reply With Quote
B is very likely to be an output due to the following logic:
A has a single pipe attached to it (it from the tank). There's very little reason to have a second line associated with it.
Meanwhile line B has a t-piece. This may well take the fuel to two banks of carbs.
Therefore logically A is the in and B is the out
