F1 2020 on a sub standard PC or ps4 /xbox
steve m - 21/7/20 at 07:09 PM
Hi Guys
Just wondering if any of you are playing F1 2020 ?
and if so , does it play ok on a sub standard pc ?
My pc is i5 64 bit, 16 ram, but does not have a graphics card, and I cant find one that will fit
I don't want to buy the game (44) for it to do nothing
steve
[Edited on 22/7/20 by steve m]
Slimy38 - 21/7/20 at 08:06 PM
Try this;
https://www.systemrequirementslab.com/cyri
However I can say with fair certainty that without a graphics card you won't get anywhere near.
Out of interest, why won't it fit? No PCI Express slot? Or is it a physical limitation? So graphics cards can be found in half height configuration, although they can be a bit more expensive.
mcerd1 - 21/7/20 at 09:08 PM
if its just a physical space issue you might be able to do something with one of these: link
steve m - 21/7/20 at 11:04 PM
My new pc is a mini tower, and the Nvdia graphics card is about two times two big
BenB - 22/7/20 at 06:20 AM
What CPU is it? Some of the newest AMD APUs might but can it definitely not fit a SFF card? Most powerful one I'm aware of is the GeForce GTX 1050 Ti 4GT LP. Performance is never going to be the best as often in v small systems the psu is a bit anaemic. If the computer has a thunderbolt3 port (or could have one added via a card) you could add an external gpu though they're fairly expensive for what you get. I'd even consider running a pcie cable and power supply out the back and use an external standard card- proper ghetto install.
I just had a quick search Ryzen 3400G APU with a slight OC runs F1 2019 at average fps of 61 on medium.
steve m - 22/7/20 at 07:31 AM
I am thinking of getting an xboxone or ps4, as my PC is in the spare room, yet if I go down the F1 game, this will be done in the garage, as there's no car in there anymore
xboxones on ebay are cheaper than half decent graphics card
My Pc comes up as the following
Processor
Processor
Intel(R) Core(TM) i5-4590 CPU @ 3.30GHz
Manufacturer
Intel
Speed
3.3 GHz
Number of Cores
4
CPU ID
BFEBFBFF000306C3
Family
06
Model
3C
Stepping
3
Revision
Memory
RAM
8.0 GB
Video Card
Video Card
Intel(R) HD Graphics 4600
Manufacturer
Chipset
Dedicated Memory
113 MB
Total Memory
3.0 GB
Pixel Shader Version
Vertex Shader Version
Hardware T & L
Yes
Vendor ID
8086
Device
0412
Plug and Play ID
VEN_8086&DEV_0412&SUBSYS_06121028&REV_06
Driver Version
20.19.15.4835
Operating System
Operating System
Windows 10
Service Pack
0
Size
64-bit
Edition
Version
10.0.18362
Locale
0809
BIOS
BIOS
BIOS Date: 08/20/14 21:47:56 Ver: A05.00
Version
Manufacturer
Dell Inc.
Date
08/20/14
Sound
Sound Device
Realtek High Definition Audio
Driver
6.0.1.6086
Drives
DVD
PLDS DVD+-RW DS-8ABSH
CD
Size
930 GB
Free Memory
851 GB
Software
Internet Explorer
11.900.18362.0
Chrome
84.0.4147.89
Firefox
Safari
Java
Flash
DirectX
11.0
.NET
4.8
QuickTime
Adobe PDF Reader
20.9.20074.61578
liam.mccaffrey - 22/7/20 at 07:52 AM
is it a dell mini tower by any chance,
I have a i5 4590 and installed a GPU, if it is a dell you may also need a different PSU and also a power adapter
I know you can get the GTX 1050 in a half size card
[Edited on 22/7/20 by liam.mccaffrey]
steve m - 22/7/20 at 07:56 AM
Yes it is a Dell mini tower/destop
Ive just noticed it says 8.o ram, yet I was positive it was 16 ??
that will be the next problem!
steve
liam.mccaffrey - 22/7/20 at 08:06 AM
what is the model number of the pc 7020/9020 etc
with the mini towers you can't upgrade the PSU (easily) so any GPU may be marginal for power comsumption. I think the standard dell ones are 290w.
I think the low profile/low power GTX 1050 "might" be ok.
I've just done all this and bought a 7020 Desktop tower as they use a stadart ATX size power supply. Still had to buy an adapter harness as some dell mother boards use a non standard connector
Slimy38 - 22/7/20 at 09:27 AM
I would agree with this, by the time you've bought the graphics card, and the memory, and the extra PSU you'll need, and then found something else that is a bottleneck, and after all that find you can only play it on minimum settings anyway, you'd be better off with an Xbox.
Although I would probably suggest PS4, but I have a bit of a bias there!
steve m - 22/7/20 at 09:30 AM
Thanks guys, I appreciate your help, yet again
Now its a mass debate of Ps4 v Xbox, and I know less than nothing on either !!
steve
liam.mccaffrey - 22/7/20 at 09:57 AM
I believe the xbox is generally better for racing type games. Though im no expert.
tweek - 23/7/20 at 10:33 AM
Personally, I would not be investing in a current gen console right now - PS5 / Xbox Series X are due at the end of the year.
Once that happens, you've got maybe 6 months to a year before PS4/XboxOne new releases stop entirely.
