Author: Subject: what kind of fuel pump for gsxrk8 ?
chunky2772
posted on 29/7/10 at 08:56 PM Reply With Quote
can anyone recomend what kind of fuel pump i will need to run my 2008 gsxr1000 in my locost i.e. what make is best, and a link to a seller of this kind of pump would be great. thanks from mick!
MikeFellows
posted on 29/7/10 at 09:33 PM Reply With Quote
if you mean a 08 busa
depending on your tank you can use the standard fuel pump from the busa.
PAUL FISHER
posted on 29/7/10 at 09:37 PM Reply With Quote
I always advise, use original equipment where ever possible.
http://cgi.ebay.co.uk/2009-SUZUKI-GSXR-1000-K8-FUEL-PUMP-/390192509154?cmd=ViewItem&pt=UK_Motorcycle_Parts&hash=item5ad94930e2
chunky2772
posted on 29/7/10 at 09:45 PM Reply With Quote
i have got that pump off the bike paul will this be powerfull enough to pump the fuel from the tank at the rear of the car to the engine up front?
omega 24 v6
posted on 29/7/10 at 10:23 PM Reply With Quote
mines does. GSXR pump gsxr injectors so as already said a balanced working system already tried and tested. you will need to mount the pump in the bottom of the tank mind. Also only needs one feed line as pressure is regulated internally and no need or swirl pots etc.
Someone on here had a craking pic of one mounted in the base of the tank ( can't remember who though)
bigrich
posted on 30/7/10 at 05:45 AM Reply With Quote
zx10r pump but same idea
omega 24 v6
posted on 30/7/10 at 06:12 AM Reply With Quote
thats the picture
dazzx10r
posted on 30/7/10 at 08:08 AM Reply With Quote
Use the std GSXR one, they are good for upto 190bhp @ wheel in the bike.
[Edited on 30/7/10 by dazzx10r]
motorcycle_mayhem
posted on 30/7/10 at 12:39 PM Reply With Quote
Std pump works great, as does any aftermarket pump, with a pressure regulator off a T somewhere (and it's return to the tank).
I use the next-up from the smallest Zytec one (8mm push-on fittings), no problems.
motorcycle_mayhem
chunky2772
posted on 30/7/10 at 07:37 PM Reply With Quote
excellent! (bigrich) what did you use to stop fuel leaking from bolt fittings, as the rubber seal for the pump sit inside the dia, of the fixing bolts. i am worried that fuel will find it way through the bolt threads!
omega 24 v6
posted on 30/7/10 at 10:15 PM Reply With Quote
I did the same as bigrich BUT i tapped right through the tank ring befoere welding it in place. I then fitted a dowty seal to each of the bolts and threadlocker to the threads before screwing them home ( heads inside the tank ) the fitted the pump from below using nuts and washers.
chunky2772
posted on 30/7/10 at 10:52 PM Reply With Quote
sounds good to me im gona do the same.that solves that little problem thanks.
