andrew-theasby
posted on 23/1/11 at 08:15 PM |
6" and 8" wheels
Are the thoughts on 6" fronts and 8" rears the same for 15" wheels rather than 13"? as i can only really find minilites
available in these sizes. Also whats the optimum tyre sizes on these rims? Thanks
beaver34
posted on 23/1/11 at 08:47 PM |
I'm going to run them, I have the rears not the fronts yet
Was thinking 195 50 up front and 215 50 or 45 at the rear
andrew-theasby
posted on 23/1/11 at 08:58 PM |
Which wheels do you have, are they available in 15x6?
carpmart
posted on 23/1/11 at 09:07 PM |
beaver34, I'm still looking for the 6" 108 PCD alleycats, looks like you've had no luck either!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
beaver34
posted on 23/1/11 at 09:39 PM |
Rears are image split rims mini lite style, was just going to run some normal 15 x 6 if they do mini lites in that or 15 x 7
Your welcome to borrow my wheels to check width and offsets
andrew-theasby
posted on 23/1/11 at 10:32 PM |
Thats good of you thanks, ill bear that in mind when i get my tub on, but not ready to order them at the mo, just checking ebay before i buy new ones
later.
Yazza54
posted on 23/1/11 at 11:15 PM |
Edit : I'm stupid
[Edited on 23/1/11 by Yazza54]
I'm unhappy cos I eat and I eat cos I'm unhappy
dirth
posted on 24/1/11 at 10:52 AM |
Donkervoort used 6,7,8 and 10 x 15 Revolutions.so google Revolution...these are also available in 6 and 8 x 13
Frosty
posted on 24/1/11 at 03:02 PM |
Surely you're doing this backwards?
Why are you picking optimum tyres to suit rims? You should be picking optimum rims to suit tyres.
andrew-theasby
posted on 24/1/11 at 06:39 PM |
ok, what are optimum tyres then for 15" rims, all i know is caterham use 6and 8" rims, but in 13"dia. Id copy their tyre size, but
there might be a better profile on 15's
dirth
posted on 24/1/11 at 06:41 PM |
205/50 x 15 front and 225/50 x15 rear..........you could go as low as 195/50 x 15 front....I don't think I would though
I also wouldn't go for a lower profile ie 45 as the ride would be terrible
[Edited on 24/1/11 by dirth]
andrew-theasby
posted on 24/1/11 at 06:42 PM |
Thanks, what size rims would they suit best?
dirth
posted on 24/1/11 at 06:47 PM |
7 and 8 inch..........I've used that combination on loads of cars...........
I think Dax used that combination,and went up to a 10 rim with a 285/40 x 15, which is far too big with such a light weight
andrew-theasby
posted on 24/1/11 at 06:52 PM |
ok ta, just want to get it right from the start so i can drop a 20let in when im ready for it.
phelpsa
posted on 24/1/11 at 07:32 PM |
205 and 225 is massively over tyred for most sevens. What power are you running?
andrew-theasby
posted on 24/1/11 at 08:02 PM |
Probably 175hp to start then 200-220 if i do the conversion
dirth
posted on 24/1/11 at 08:07 PM |
Check out the Donkervort site and also ,I think Mohr(german)that is more or less a Dax
Style of wheels?
Compomotive do a ML,very similar to Minilite,there is still a Performance wheel in that pattern(personally I don't rate them)
or what about the TH from Compomotive
Frosty
posted on 25/1/11 at 03:38 PM |
The process should be as follows:
1) Work out what type of tyres you want to run. Semi slick, road, soft compound, hard compound, etc.
2) Work out which tyre widths front and rear will be suitable, based on type of tyre choice (the wider you go, the cooler they will stay). Don't
think wider tyre = more grip like most people do. Be sensible with your tyre choices. Something like a 185 front and 205 rear will work well with a
semi slick. If you go much wider you'll struggle to heat them. On a road tyre, you may not want to go as wide, since the compound will be harder
and therefore harder to heat.
3) Based on your ideal widths, look at the tyre wall height options. Most 7's run a tall sidewall which works well.
4) Now you have picked your tyres, go on to the tyre manufacturers website and look up the tyres. It will give you a minimum, maximum, and ideal rim
width for the tyre size. Best to start with the ideal width if possible, which gives you room to move up or down a little in tyre width if you need
to.
5) Work out your offsets based on rim width.
Tyres weigh a lot. They can often weigh more than the rim they are placed on, so make sure you don't over-tyre the car, adding unnecessary
weight to all 4 corners of it when you do not need a wide wheel and tyre in the first place.
Hope this helps.
