Author: Subject: Ground Anchor Recommendation for Block Paving
James
posted on 7/9/11 at 08:40 AM Reply With Quote
As I type we're having, at long last, our drive block paved. Had considered doing it myself and did a lot of research but decided I'd still be working on in on 2021 so got the professionals in.
One thing we're looking forward to is getting my girlfriends motorbike off the back lawn and onto the new drive... but what to do about securing it.
Want to fit a ground anchor or some sort. The driveway guys are more than happy to do it for us.
Guessing it will involve a large block of concrete or something under the new blocks- no point just bolting the anchor to a single brick!
So, any recommendations on a good ground anchor- secure but not too visible/eyesore. And suggestions on how best to fit it to block paving? The pavers are 50mm thick, so the buried bit needs to be long enough to cope with the top 50+mm of it not being in anything secure. Only below the 50mm will be solid.
Thanks!
James
[Edited on 7/9/11 by James]
big-vee-twin
posted on 7/9/11 at 08:46 AM Reply With Quote
Just concrete it in link
http://www.triangleltd.com
scudderfish
posted on 7/9/11 at 08:57 AM Reply With Quote
Chain it to a Pinto?
stevebubs
posted on 7/9/11 at 09:21 AM Reply With Quote
Y anchor ?
mcerd1
posted on 7/9/11 at 09:23 AM Reply With Quote
a guy I used to work with got some super high grade chain (I think he said its the stuff fishing trawlers use in some of there nets...) the sort that angry grinders have a hard time cutting
but he couldn't get a padlock to match that - so drilled a couple of holes through the wall of his house so the padlock ended up inside his hallway cupboard
[Edited on 7/9/2011 by mcerd1]
stevegough
posted on 7/9/11 at 09:25 AM Reply With Quote
Beware with block paving - prepare the ground underneath first, and ensure the dreaded weeds can't penetrate. I spent a full 3 days a couple of weeks ago powerwashing ours ( we've got about 70 sq metres of it ). I'm almost ready to take it all up.
I know you said you're getting it 'professionally done' - Hah! - think they'll do it properly? cobblers (pun intended).
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
posted on 7/9/11 at 09:26 AM Reply With Quote
I'd say this is an ideal opportunity to install a folding or telescopic ground anchor and have the driveway people cut the blocks around it so it lies completely flush when not in use. This way you have a completely flat surface, no trip hazard.
http://www.discountlocks.co.uk/Ground-Anchors-s/293.htm
Daddylonglegs
posted on 7/9/11 at 10:01 AM Reply With Quote
Originally posted by stevebubs
Y anchor ?
Y not?
I agree, though, concrete it in.
jossey
posted on 7/9/11 at 11:39 AM Reply With Quote
in my garden for my caravan we welded up a long metal pole into the ground with stalks coming out 6"-10" and about 10 of them under the gound to ensure it cant be pulled out.
The hole was about 2 foot wide.....
then put the pole in the ground sticking out about 1 foot.
then poor 5 bags of postcrete into the hole and add water. then its done.
Just drill the pole and your sorted to bolt it to your car or caravan and your away.
we then paved over the top of it and drilled a hole for the pole to fit through.....
good luck.
David Johnson
stevebubs
posted on 7/9/11 at 12:04 PM Reply With Quote
Y anchor ?
Y not?
?? http://www.yanchor.com/
907
posted on 7/9/11 at 01:54 PM Reply With Quote
I have 3 of these; one in the drive, one in the garage, and one in the lawn.
Easy to make. Two half circles of plate with a strip to join them.
A thick round bar between, and weld bits of round bar on the bottom
till it looks like a porcupine.
Paul G
posted on 7/9/11 at 03:51 PM Reply With Quote
Paul G
I like that!
You could make it exactly the size of a pavoir , but projecting 50mm above the sub base concrete lump. That way you'd have a flush fitting anchor point and a very neat finish to the blocks rather than having to cut round a pole. Make from stainless so it doesn't rust though as the rust will discolour the surrounding blocks.
907
posted on 7/9/11 at 04:55 PM Reply With Quote
Paul G
I like that!
That one is stainless. I suppose I should have polished the weld discoloration off. (Me bad )
One thing I do advise is a little hole in the bottom for a drain. Mine fills up with water.
Paul G
tompat3463
posted on 7/9/11 at 05:08 PM Reply With Quote
why not get them to lay a concrete pad like 60m below finished ground level then complete the drive (remembering where the pad is. Then U could simply drill a 12mm hole thry ur block thru the sharp sand and into ur conc pad and use a chemical achor epoxy resin to set an eye in or what ever ur anchor choice is !!
locoboy
posted on 7/9/11 at 05:49 PM Reply With Quote
Have a look at www.bulldogsecure.com
Let me know if there is anything useful and i will get a price for you - i get it at their best trade price.
Locoboy
Guinness
posted on 7/9/11 at 06:42 PM Reply With Quote
Another vote for the Y anchor.
