New Topic New Reply
Author: Subject: Coilpack mounting - Nodiz
johnemms
posted on 8/10/12 at 05:54 PM Reply With Quote
Putting together my NODIZ ignition system..
Bits arrived today 1pm - all up and running at 5pm
Removed distributor..
Cut up an old dizzy..
Nice platform for the coilpack :p
(Now fitted will post a pic tomoz)
[img][/img]
[Edited on 8/10/12 by johnemms]
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
greed1
posted on 8/10/12 at 06:25 PM Reply With Quote
Looks like a good place for it. Does it fit under the manifold ok
How much was the nodiz system it's something I looking at for my next upgrade
Drive it stright sideways
johnemms
posted on 8/10/12 at 11:15 PM Reply With Quote
Hight Depends on your choice of donor distributor and coil pack..
This is quite high and just about fits..
Price for NODIZ is cheaper than Megajolt...
But check price with Matt
He has a rolling road available to tune it up when fitted
blakep82
posted on 8/10/12 at 11:19 PM Reply With Quote
wish i' known about this system before i went with MJ.
I like MJ, but the nodiz system would have worked so much better with the vauxhall engine's internal trigger, rather than mounting one on the crank, and brackets etc. love the whole bluetooth thing too. and i'm currently getting a loom built including the MJ, so too late to change now. maybe later... looking forward to seeing how it all goes together
________________________
johnemms
posted on 9/10/12 at 07:34 AM Reply With Quote
Well.. I read up on what I needed to do in advance..
Made bracket & fitted TPS - Saturday..
Made a home for the coilpack - Sunday..
Fitted trigger wheel/sensor/wiring - up & running - Monday
Today will wire in TPS and look at mapping...
The TPS is off a Rover scrap yard..
(The adapter is a 30amp brass conector drilled out and tapped 7/16UNF)
Oh yeah - the control box is the size of a packet of fags.. No EDIS needed either .. Simples :p
[img][/img]
[Edited on 9/10/12 by johnemms]
mtechmatt
posted on 9/10/12 at 08:14 AM Reply With Quote
John,
Glad to see its all working well. I will have some new 'goodies' software wise for you in the next week or so
Matt
V4 Engine Management System | Online Shop | Rolling Road Tuning | Motorsport Preparation | Engine Packages | Throttle Bodies
Check out what's happening in the workshop via our Facebook Page:
The Workshop
MEGASQUIRT ROLLING ROAD & BIKE CARB TUNING SPECIALISTS
www.mtechautomotive.co.uk
johnemms
posted on 9/10/12 at 08:27 AM Reply With Quote
Cheers Matt ...
soooo simple to put together & only the size of a pack of ciggies!
Kicking out the external EDIS is a stroke of genius..
So tidy..
Ahh my rover TPS wires.. for reference..
Pin 1 Pink/Purple 5 V Supply from ECU
Pin 2 Green/Yellow Sensor position output
Pin 3 Pink/Black Ground
Swap pink wires over if TPS reading wrong way
mtechmatt
posted on 9/10/12 at 08:39 AM Reply With Quote
John,
I will add them to the manual.
Matt
The Workshop
johnemms
posted on 9/10/12 at 10:58 AM Reply With Quote
Thats it for now .. all plumbed in..
Old dizzy & coil out .. big spark coil pack & tiny blutooth ignition in
[img][/img]
[img][/img]
mtechmatt
posted on 9/10/12 at 11:09 AM Reply With Quote
John,
Really nice install...
Could you post the pics of the NODIZ unit fitted and crank wheel to our facebook page please?
http://www.facebook.com/pages/Nodiz-Pro-Ignition-Controller/402122336503751?fref=ts
The Workshop
johnemms
posted on 9/10/12 at 01:34 PM Reply With Quote
Posted a few pics of my quick installation on Facebook
Opened up spark plugs to 30 thou to take advantage of larger coil
Running good..
Looking forward to trying a few maps out..
mtechmatt
posted on 10/10/12 at 01:18 PM Reply With Quote
So I here you have been out test driving?
The Workshop
New Topic New Reply
