Author: Subject: Removal of shackle bolt MG TC
SteveWallace
posted on 21/10/14 at 09:17 PM Reply With Quote
I've now reached the stage in my MG TC restoration where I'm virtually down to the bare chassis. The only things left to remove are the shackle bolts that the leaf spring carriers hang off. I've tried WD40 and a hammer, but try as I might, I cannot get the shackle bolts out of the chassis. They have been in place for 65 years, so its surprising really that its the first bit that I've been really stuck on.
You can see one in the photo. The part that looks like a fat washer with a bit of blue/grey paint on it is actually part of the shackle bolt, otherwise I would have been able to simply put an oversized socket over the shaft and then wind the nut back on with a breaker bar to pull it out. I don't want to heat the chassis if I can help it, because if I break it at such a critical place then I'm really in trouble. I probably wouldn't bother, but the off-side one is bent so needs to be replaced. By the way, they are metal in metal, there are no bushes at this point that I could have melted or drilled out
Any suggestions??
posted on 22/10/14 at 06:13 AM Reply With Quote
You need heat on it, a concentrated "sharp" flame not a blow lamp.
v8kid
posted on 22/10/14 at 06:30 AM Reply With Quote
Is the bolt disposable I often weld a nut on the heat cracks the bond and its handy for applying torque
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
monkeyarms
posted on 22/10/14 at 07:16 AM Reply With Quote
If you have a compressor, an air impact hammer is the right tool for the job.
mookaloid
posted on 22/10/14 at 08:46 AM Reply With Quote
You could leave it and just straighten the other side using heat and ingenuity?
posted on 22/10/14 at 10:28 AM Reply With Quote
Electrolysis! Try and get the offending area in a container and zap it overnight. That will get if free with no fear of any damage.
Mr Whippy
posted on 22/10/14 at 12:12 PM Reply With Quote
Personally I'd just use a blow torch but my method my not be the right one…
It is strange that it isn’t budging since it doesn't look corroded, are you sure they come off? Or maybe a left hand thread some other weird thing being such an old car. I think I'd speak to a specialist in the old MG's before going there gung ho and breaking something needlessly
cs3tcr
posted on 22/10/14 at 02:46 PM Reply With Quote
Have a read here:
Pin removal
Part way down the page I think it gives an idea of what is required.
Rod
[Edited on 22/10/14 by cs3tcr]
posted on 22/10/14 at 03:59 PM Reply With Quote
Electrolysis will still help in getting it loose
cs3tcr
posted on 22/10/14 at 04:30 PM Reply With Quote
It would help. Looking at the picture on the link I posted, once removing the taper pin, you should be able to rotate the pin with suitable pliers/weld a bar on etc to free it up. But for the life of me, I cant recall seeing the taper pin on the various TC chassis that came through the shop I used to work at, though I never did look at them in detail. The picture of the pin in the Moss Europe catalog shows the new pins have flats machined on them, which I would assume is for holding the pin in the correct orientation while installing them. But, they are bloody expensive.
Rod
SteveWallace
posted on 22/10/14 at 09:12 PM Reply With Quote
Thanks for the advice guys. As far as I can see, the shackle bolts at the front of the rear springs screw in and may be held with a taper pin, but looking at the parts catalogues it looks as though the rear one just pushes in. Unfortunately, its a rear one that I need to get off.
One of the problems is that the bit that looks like a fat washer has a flat on one side that mates with a flat on the chassis cross bar above it. This means that you cannot apply torque to the pin to break the rust seal. Unfortunately, I don't have a torch with a fine flame (only a blow lamp) and I don't have a windy gun to hammer it out. I'm reluctant to try and straighten it in situ because its large diameter and something else might give first (yes, I know that someone managed to bend it without breaking anything, but it still seems to be risking the chassis to me).
I like the idea of electrolysis. As the chassis is now stripped its easy to turn it on its side, so I could do that and dip the shackle bolt into a bucket of electrolyte.
I'll have a go at a couple of things and report back
posted on 22/10/14 at 09:32 PM Reply With Quote
Yes go for it. Tried electrolysis before? You be amazed at the things it can do...
paulf
posted on 22/10/14 at 09:47 PM Reply With Quote
I would get a bit of thick wall tube that just fits over the pin and about 2 foot long and weld it to the flange on the pin, then find a suitable piece of metal to use as the weight for a slide hammer and fit that followed by welding a bit of bar across the end of the tube to hammer against.With some gentle heat and release fluid you may then be able to slide hammer it off.
Paul
SteveWallace
posted on 29/10/14 at 02:53 PM Reply With Quote
I finally managed to get it off by doing the following
I) Stood the chassis on its side. On the inboard side of where the shackle bolt goes through the chassis, the mounting point is a larger diameter than the bolt so it creates a sort of well which I filled with Plus Gas and left for a few days.
ii) I then got an old drill bit and put in in my drill the wrong way around (so that it had a flat end rather than the drill tip), put the drill on its hammer setting (the one that you use for drilling masonry) and used it to vibrate the bolt as long as I could stand it (ear defenders needed). My logic was this all this vibration and hammering might release the rust or allow the Plus Gas to penetrate further.
iii) Applied more Plus Gas and left it another day
iv) Tried to drive the shackle bolt through with a drift and hammer and hey presto it came out.
I'm not sure which of the above steps did any good, but I got the right result.
posted on 29/10/14 at 04:06 PM Reply With Quote
Well done, I'm sure the electrolysis would have done the same and made it easier to remove.
SteveWallace
posted on 30/10/14 at 05:25 PM Reply With Quote
I now have a big pile of rusty bits where there used to be a car, so I'm sure that electrolysis will come in useful for cleaning some of those up prior to re-painting.
posted on 31/10/14 at 03:04 PM Reply With Quote
Indeed it will, anyvquestions just ask...
