Author: Subject: Is 350lb springs to much for widetrack front end
furryeggs
posted on 20/3/17 at 07:16 PM Reply With Quote
I have everything on the car now other than nose cone and bonnet and its sat on the ground, I have 40mm wider wishbones on the front with 350lb springs. everything reated and settled ok. The springs are right at the bottom of the shock so i can't lower the front any further but can raise it. Will 300lb springs allow it to sit a little lower and give me more adjustment.
Tiger Avon
2.0 Zetec
Nickp
posted on 20/3/17 at 08:01 PM Reply With Quote
Sounds like you just need shorter springs.
sam919
posted on 20/3/17 at 10:58 PM Reply With Quote
If you could post a photo. Generally with a longer wishbone you have stiffer springs.
laptoprob
posted on 21/3/17 at 08:31 AM Reply With Quote
i had the same wishbones as yourself and used the std shockers but re-used the std pick up points so nothing changed although i uprated to 400lbs fronts.
The problem you have in my opinion is that it sounds like you have tried to use a lower mounting point that's further towards the wheel than std?
If thats the case then the shocker wont be long enough!
[Edited on 21/3/17 by laptoprob]
http://www.youtube.com/watch?v=ajlF4nWJtGA
furryeggs
posted on 21/3/17 at 12:37 PM Reply With Quote
I got longer shocks aswell as wishbones.
laptoprob
posted on 21/3/17 at 12:41 PM Reply With Quote
so when your spring is fully extended is there any thread left to take a longer spring if you had one??
johnemms
posted on 21/3/17 at 02:33 PM Reply With Quote
First - trawl all of Locostbuilders forums - research - etc....
Then take out the springs..
Lower car till sump almost touches the ground..
Now make and fit bump stops to dampers .. (I used skateboard wheels)..
Lower car without springs car should have safe sump clearance
Raise car fit and adjust springs/ride height..
I'm running soft 250lb front this year.. and playing with dampers from soft to firm..
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
