Author: Subject: R1 powered cooling questions
Ciaran
posted on 23/5/17 at 07:09 PM Reply With Quote
Recently bought a full built R1 equipped car
When driving the coolent temp varies between 70 and 95 degrees dependant on load.
Basically the system doesn't have a thermostat fitted so looking to fit one.
What is the ideal operating temperature?
Is the thermostat fitted inline?
Is it fitted on the supply to the radiator or return?
Anything else I need to consider?
Ciaran
CosKev3
posted on 23/5/17 at 07:48 PM Reply With Quote
Which R1 engine?
Thermostats go in the outlet from the engine to the top of rad 99% of times.
If it's a early R1 the thermostat is fitted where the two pipes exit the head between the plug holes
CosKev3
posted on 23/5/17 at 07:50 PM Reply With Quote
That is a early R1 thermostat unit,although I've modified it to take AN pipework and added the temp senders
Ciaran
posted on 23/5/17 at 08:12 PM Reply With Quote
Engine code is 4xvoo
And yes it looks like the one you put above
How do I host pictures on here as photobucket doesn't seem to work
[Edited on 23/5/17 by Ciaran]
CosKev3
posted on 23/5/17 at 08:46 PM Reply With Quote
So there is no thermostat in that housing?
Ref pics,upload them into your archive on here,then copy and paste the forum code
Ciaran
posted on 23/5/17 at 09:15 PM Reply With Quote
Judging by the temperature fluctuations I would say there isn't one or it's not working.
If I split the thermostat housing is there any seals I might need?
CosKev3
posted on 23/5/17 at 10:30 PM Reply With Quote
The thermostat sits in a rubber seal,which then gets sandwiched between the housings to seal it.
Pretty sure a stat and seal are knocking on 50
CosKev3
posted on 24/5/17 at 06:42 AM Reply With Quote
https://www.fowlersparts.co.uk/parts/view/4FM-12410-00
Ciaran
posted on 24/5/17 at 06:45 AM Reply With Quote
Do my best not too damage it then
