New Topic New Reply
Author: Subject: VW caddy brakes gone
KitCatE1
posted on 12/11/17 at 07:42 PM Reply With Quote
Hi all bought a caddy a little while ago itís been fine drove it 80 mile yesterday when I got home rear wheel was red hot could feel the heat as I walked past brakes were working fine. Got it out the garage today and the brake pedal is solid and have to stamp hard on it for any effect any ideas what has happened? Iím guessing itís called cooked the caliper?
daviep
posted on 12/11/17 at 08:40 PM Reply With Quote
Wouldn't have thought one seized caliper would give you the symptoms you describe?
Have you checked that there is servo assistance?
I'm sure you already know but in case not here how to check servo operation. With the engine stopped pump the brake pedal five or six times to deplete any vacuum in the servo, and then hold it down hard, with the pedal still down start the engine and the pedal should drop a little as the servo applies a bit more force to it. If this doesn't happen find out whether it is a vacuum problem or a servo problem.
Davie
ďA truly great library contains something in it to offend everyone.Ē
KitCatE1
posted on 12/11/17 at 09:41 PM Reply With Quote
Thatís what I donít get pedal feels fine when I start the van one pump of the brake and the pedal becomes solid it drove perfectly all the way home on the motorway then 4miles of B roads everything perfectly fine 16 hours later sat in the garage this happens had it in the air wheel is moving freely Iím baffled
posted on 13/11/17 at 05:16 PM Reply With Quote
Is the Caddy a petrol or Diesel engine? If petrol check the vacuum hose for splitting especially near the inlet manifold also the non return valve by disconnecting the vacuum pipe from the servo , run the engine and check for vacuum at the disconnected end. For Diesel engines check the above , if you have no vacuum it could be the vacuum pump .
KitCatE1
posted on 16/11/17 at 01:17 PM Reply With Quote
Itís the 1.9 Tdi pd engine finally had time to have a look today Iíve replaced the calliper as itís shot piston royally seized and rubber all perished wheel now free again defiantly seems to be an issue with the vacuum pump or the pipe work near it servo assistance is present when I wiggle the pipe at the rear of the pump brakes are perfect then go again wiggle again and fine again for a few seconds pipes have some oil in there as well may well just be best swapping out the pump as the rear outlet is loose somehow
ian locostzx9rc2
posted on 16/11/17 at 06:15 PM Reply With Quote
The plastic vac pipes normally split ?
New Topic New Reply
