Author: Subject: zzr1100 wiring
nick9one1
posted on 17/7/18 at 03:15 PM Reply With Quote
zzr1100 wiring
I'm now at the point where I'm wiring the bike loom to the car.
I've stripped out a lot of the loom already, lights, clocks etc.
For simplicity I think I'd also like to ditch the junction box and fuel pump relay.
Am I right in thinking I can just power the fuel pump from a switched 12v supply?
I've colour coded the remains of my stripped loom
russbost
posted on 17/7/18 at 04:41 PM Reply With Quote
I'm rather rusty on the ZZR1100 now, long time since I did my twin ZX10's which is basically the same engine & loom. When I did mine I kept the junction box simply because I wasn't certain of everything it did? I was never clear on what the block of 4 terminals shown in the centre of that junction box did?
However, that said it's a very simple engine/loom & certainly no reason why you can't just run the pump from a fused ignition feed, it is after all only a low pressure pump
Don't forget the 100 ohm resistor in the feed to the igniter, grey wire IIRC unless you're running the original ign sw.
Atr present your diagram appears to be showing the side stand & neutral wiring still being part of the loom, unless you only want to be able to start in neutral you'll need to bridge those out, I put my light green to earth back at the junction box & disconnected the front section from the back if you follow me, so it kept the neutral light, but got rid of the "in gear defeat", I also connected green/white to earth to get rid of side stand sw. - but if you're getting rid of the junction box, then I think you will automatically remove those
Furore Formula Car - the only two seater modern Formula Car lookalike. I no longer run Furore Products or Furore Cars Ltd, but would still highly recommend them for Acewell dashes, projector headlights, dominator headlights, indicators, mirrors etc, best prices in the UK! Take a look at http://www.furoreproducts.co.uk/ or find more parts on Ebay, user names furoreltd & furoreproducts, discounts available for LCB users.
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member   russbost 's Aim
nick9one1
posted on 17/7/18 at 07:46 PM Reply With Quote
Thanks! I'd read about the resistor but had forgotten.
I'm struggling to understand the junction box diagram too, although I think I have it cracked now.
Basically the only pins from the junction box that matters is the Yellow/Red, which is a switched 12v to the starter - This can be supplied 12v from a key or momentary start button.
how to delete your
then I realised I had a D2 nota D3..
ammonium sulfate symbol
[Edited on 17/7/18 by nick9one1]
russbost
posted on 18/7/18 at 07:09 AM Reply With Quote
That actually is far simpler! & yes, can't see any reason not to ditch the junction box, you should be able to get rid of a substantial chunk of loom too!
Don't forget you will still want the front "half" of the LG wire for your neutral light
nick9one1
posted on 18/7/18 at 09:06 AM Reply With Quote
I just found this diagram elsewhere on the forum...
It's for the 2 plug C models not the 9 pin single plug D's. But it certainly helps a lot.
[Edited on 18/7/18 by nick9one1]
