Author: Subject: Emerald K series ECU views??
r1_pete
posted on 15/1/20 at 10:35 AM Reply With Quote
What are peopleís views of Emerald K3 ECUs.
Have chance of one reasonably priced, half the pre vat list price, would be to run a 1991 engine so no frills needed.
Iíve no experienc of Emerald only Megasquirt / Tunerstudio, so wondered how good / bad / indifferent they are.
Cheers.
[Edited on 15/1/20 by r1_pete]
Myke 2463
posted on 15/1/20 at 11:52 AM Reply With Quote
My k3 has been in constant use since 2009 when set up by Dave walker in hot / cold / dry / wet weather summer and winter and never missed a beat.
After sales is very good, just ring them and they will sort you out. Just keep dry like all ECU's.
Be Lucky Mike.
40inches
posted on 15/1/20 at 12:32 PM Reply With Quote
Cheers.
I think Emerald are Jools ECU of choice Pete
r1_pete
posted on 15/1/20 at 04:59 PM Reply With Quote
Cheers chaps, Iíll go for it, has to be better than 1980s EEC Technology too
posted on 15/1/20 at 10:04 PM Reply With Quote
On highly modified engine yes but even the early versions of Rover MEMS were pretty good because they use a MAP sensor as the main fueling sensor and that makes relatively flexible to engine changes. You can make big changes to the airfilter, throtlebody without it upsetting the air-fuel ratio.
[I] ď What use our work, Bennet, if we cannot care for those we love? .Ē
r1_pete
posted on 15/1/20 at 11:29 PM Reply With Quote
The EEC 4 my engine used doesnít have map capability, used maf air temp and tps....
The Emerald can be configured for a map sensor, which is the plan now, it has a few user defined ports so may also look into maf.
BaileyPerformance
posted on 6/2/20 at 09:59 AM Reply With Quote
What car / engine are you putting the Emerald on?
If your referring to Ford EEC then the Emerald would no be "better", its only advantage is its laptop mappable.
r1_pete
posted on 6/2/20 at 08:08 PM Reply With Quote
Itíll be going on a 24V Ford BOA V6, in a Reliant Scimitar, I did have the EEC-IV, and had the majority of the pinouts identified, but the Emerald came up, and I ended up a few ££ up on selling the EEC and loom Iíd made.
Still trying to figure how MAP works, seems its a trim on top of TPS rather than instead of.....
40inches
posted on 6/2/20 at 11:14 PM Reply With Quote
Give Jools a call Pete, he is the Emerald man locally
BaileyPerformance
posted on 7/2/20 at 09:52 AM Reply With Quote
Emerald defaults to Alpha N, with MAP compensation on top. We have mapped a couple of turbocharged BOBs on K6.
You do not "need" MAP if your running NA, you can map the engine on TPS only. From memory you cannot change the primary fuelling to MAP only, i'l take a look later.
