Author: Subject: what top balljoints
wreckitralph1
posted on 1/3/20 at 11:42 PM Reply With Quote
what top balljoints
for mk indy top front arms ive heard transit drg links what year or part number please also are they both right hand thread or 1 left 1 right many thanks
Mr Whippy
posted on 2/3/20 at 07:48 AM Reply With Quote
I could be wrong but iirc they were Ford Transit Mk1 Mk2 Track Rod Ends like these, can't mind if they used threaded inserts in the wishbones or just plain tube, it's been a while... if you have them though just have a check, would be pointless to use left hand threads for their alternative application as suspension joints. Getting the large lock nuts is more a pain, I can't remember the thread they used.
linky
steve m
posted on 2/3/20 at 09:08 AM Reply With Quote
They are Transit mk1 track rod ends, and I believe they only come in right hand thread, and 18mm
As per the link below, these fitted my Locost perfectly
https://www.ebay.co.uk/itm/FORD-Transit-Track-rod-end-Mk1-and-Mk2-NOS-Right-hand/184189640099?hash=item2ae28edda3:g:UMQAAOSw7fVdYtGV
JAG
posted on 2/3/20 at 10:25 AM Reply With Quote
As per Steve m
I have the same part on my Locost from Stuart Taylor Motorsport.
Justin
voucht
Contributor
Posts 230
Registered 22/5/11
Member Is Offline
Photo Archive Go!
Building: Haynes roadster on the road since november 2014 bu
posted on 2/3/20 at 10:53 AM Reply With Quote
Also available from Rally Design:
https://www.rallydesign.co.uk/product_info.php?products_id=11838
For your information and for buying the right lock-nut, the thread is M18x1.50
Also wreckitralph1, could you use punctuation in your posts (periods, comas, etc.) an make proper sentences please? It would be much easier to read (at least for me!)
https://vouchtroadster.blogspot.com/
https://cafrazx550.blogspot.com/
JAG
posted on 2/3/20 at 12:48 PM Reply With Quote
#metoo
Justin
SJ
posted on 2/3/20 at 01:16 PM Reply With Quote
Just replaced mine with a couple of these:
https://www.ebay.co.uk/itm/360477993376
Stu
wreckitralph1
posted on 3/3/20 at 01:44 AM Reply With Quote
Thank you fellas.much appreciated
