JAG
posted on 4/3/20 at 01:18 PM |
Advice on using Cleco/Cleko fasteners
I'm making some new Aluminium panels and I want to temporarily fix the panel in place while I make something else that has to butt up to the
panel.
I've bought some Cleco/Cleko type fasteners from eBay. Has anyone else used them? What do you think of them?
The set I've bought has no Cleco/Cleko Pliers - do I need some?
Will I be able to fix and un-fix the fasteners without the Pliers?
Justin
number-1
posted on 4/3/20 at 01:42 PM |
I have only ever seen them used with the pliers. They work a treat.
trialsman
posted on 4/3/20 at 02:41 PM |
Get the pliers. You won't regret it. You could fab something up but....... You can put the cleco in and pull it out multiple times and still
have a good hole to put the pop rivet in. Clecos and the pliers last forever. Russ
theconrodkid
posted on 4/3/20 at 04:35 PM |
it,s what they build aircraft with so cant be that bad
who cares who wins
pass the pork pies
big_wasa
posted on 4/3/20 at 04:54 PM |
Once you have them you won’t do panels with out them again.
[Edited on 4/3/20 by big_wasa]
jacko
posted on 4/3/20 at 05:09 PM |
I use them most days at work but the ones I have have a nut you twist to tighten and untighten no pliers there great on aluminium
Graham
jps
posted on 4/3/20 at 06:24 PM |
I bought clecos and pliers from LAS Aerospace https://www.lasaero.com. Very useful to keep a panel aligned when drilling rivet holes.
Slimy38
Graham
Same here, they were a similar price to the pliers type but I didn't have to buy the pliers. The only thing I regret is not getting enough!!
The other issue is that there is a plastic face to them, which is great to not mark the aluminium. But welding (and even grinding) nearby causes them
to melt slightly. I'm fairly sure the Cleco's are all metal and would be ok with a heat source nearby.
Mr Whippy
posted on 5/3/20 at 08:04 AM |
Have to admit I regret not buying them many years ago after seeing how much swarf drops out when I take the panels off... also lets you paint the
holes before finally installing the rivets, great tools
JAG
posted on 5/3/20 at 09:17 AM |
Thanks for the replies and all the advice; I really appreciate it.
I ordered the Pliers to go with the Cleco's last night
Justin
Bluemoon
posted on 5/3/20 at 11:51 AM |
Tend not to use Celcos, skin pins with Kerneld nuts are much cheaper... (about £1 each!)...
tims31
posted on 7/3/20 at 02:43 PM |
Skinpins for me too, again used to using when doing panels on aircraft.
You can get them from here and not too
expensive.
They also do the Cleco but I could nevr get used to those after using skin pins, the skin pins hold much firmer
[Edited on 7/3/20 by tims31]
Build: http://www.martinsfurybuild.co.uk/
mcerd1
posted on 7/3/20 at 03:35 PM |
I've got a mixture of skin pins and cleco's - both have uses
Personally I like the firm grip you get with the skin pins - so I'll use these at the key points / corners...
but cleco's (with the special pliers) are so fast and easy to fit/remove they are great for less critical bits like in-between the skin pins on
long edges etc...
thats what I did for this lot (although for some reason I only took pic's with the rivets in afterwards) every rivet just dropped in as easy as
the first one
  compulsory floor panel pic
Saying that the cleco's alone still hold panels pretty well - so the skin pins are defiantly not required
these things make it even easier too, perfect spacing with almost no measuring (defiantly not required, but great if your lazy like me)
  my new favourite tool
[Edited on 7/3/2020 by mcerd1]
