Author: Subject: WTD Weber 45s
number-1
posted on 20/3/20 at 04:34 PM Reply With Quote
WTD Weber 45s
Is anyone parting with a set of Weber 45s? Its for a Zetec engine.
N1
madteg
posted on 20/3/20 at 08:53 PM Reply With Quote
Why would you want to put webers on your engine. All they will do is drink fuel and be noisey, would be a lot better with bike carbs or injection.
Who agrees with me ?
number-1
posted on 20/3/20 at 09:25 PM Reply With Quote
Hello mate. Thanks for the reply. Im pretty new to car engine cars as all of my previous have been BECs.
What sort of ideas do you have?
big_wasa
posted on 20/3/20 at 09:39 PM Reply With Quote
Do some research, but You will be very disappointed.
The reason bike carbs came about in the first place, Dcoe Webbers on a Zetec or any other 16v engine.
The progression between the idle and main jets isnt best suited to the multi valve engine. You can get the 152g five progression hole 45s but there still very expensive and hard to get working at there best.
Of course you maybe a carb guru I was not.
Having already got a programmable fuel and spark ecu throttle bodies should be the obvious choice.
number-1
posted on 20/3/20 at 09:41 PM Reply With Quote
Ive been researching for 3 days lol....and yes......it is very depressing!!!!
If i could find a way of getting my supercharger noise down then id re install it as it made 230 bhp
big_wasa
posted on 20/3/20 at 09:51 PM Reply With Quote
Why not try a small turbo then ?
number-1
posted on 20/3/20 at 09:54 PM Reply With Quote
I have no weldng/fabricating knowledge so would need something simple to fit. I did look into that but couldnt find anything suiatble. Id be after 220-240 bhp
big_wasa
posted on 21/3/20 at 10:26 AM Reply With Quote
My opinion is 220bhp ish is sensible for a standard Zetec and very easy to achieve but like the bike tbs It makes more sense the more you can do for your self.
Most Of the last generation 2.0 hot hatches put out ~220bhp as standard and will do so for over 100k Miles. They use a small turbo, low boost, medium Cr.
For a Zetec, the blacktop Focus exhaust manifold lends itself nicely to the job. Small tubular runners that keep gas flow up helping a small turbo to spool faster and giving low levels of lag. Made of steel they are easy to manipulate and will with stand repeated heat cycles better than cheap stainless steel.
You can top mount the turbo, bottom mount it.
Biggest problem is heat management.
big_wasa
posted on 21/3/20 at 10:42 AM Reply With Quote
https://youtu.be/afwiOZWXQKk
Bottom mount.
Ultra cheap. Just add turbo flange of choice. This one is a Subaru Td04
Down side, pipe work takes a bit more routing.
Top mount.
Oil supply.
Oil drain.
[Edited on 21/3/20 by big_wasa]
GavMax
posted on 21/3/20 at 06:25 PM Reply With Quote
If it helps, I have a brand new original black top injection unit if it helps.
If you look in my photo gallery under for sale you should see some photos.
It needs a new home and I'm not after a fortune for it
Gavin
