Slimy38
posted on 12/4/20 at 09:04 AM |
car jack lifting pad for car sill
My current car has nothing underneath that I would call a 'jacking point', so I need to use the sill points. But I want to use a slotted
jack pad to save collapsing the weld seam.
The proper pads aren't cheap, but it's a fairly basic design that I could cut out of a rubber block. Problem is, I don't know what
type of rubber I'm looking for. The various Ebay versions do just say 'rubber'. Is there anything specific I could look for that
would do the trick?
macc man
posted on 12/4/20 at 09:21 AM |
I found a pair on ebay less than £7. They are made of a very hard rubber.
ken555
posted on 12/4/20 at 09:28 AM |
Ice hockey puck and an angle grinder
They are about £1.50 each
[Edited on 12-4-20 by ken555]
PorkChop
posted on 12/4/20 at 09:31 AM |
Hockey pucks.
Although, seriously, just buy one (or three if you wanted to use them on axle stands), they're cheap enough to avoid all the faff of cutting
them.
[Edited on 12/4/20 by PorkChop]
Slimy38
posted on 12/4/20 at 09:40 AM |
Hockey pucks were my first thought, but they're not deep enough. Can they be glued together?
ken555
posted on 12/4/20 at 10:04 AM |
Tigerseal/PU adhesive would work, or countersunk bolts and nuts ?
the pressure is downwards so just something to hold it in place, I would think
sdh2903
posted on 12/4/20 at 10:30 AM |
I'd just buy one. Not worth the fannying around. Smaller dimension ones are available cheaper.
https://www.ebay.co.uk/itm/274304684126
Slimy38
posted on 12/4/20 at 01:53 PM |
Not deep enough unfortunately, the weight would be back on the seam rather than on the sill. I've ordered half a dozen pucks from Amazon. I want
to make up some that will fit on top of my axle stands too, although I've not yet figured out how to jack up the car and then put the axle stand
in the same place!
Mr Whippy
posted on 12/4/20 at 10:25 PM |
You should always be jacking onto wood packing. If jacking on the sill use a 1 inch thick piece at least a foot long. The teeth of the jack seat bite
into the wood fixing it in place and the soft wood will prevent the sill being damaged while also spreading the load. If resting on stands its better
to use just the stand (not the extension) so the tube also bites into the wood. This is my Fiesta resting on stands and this is the only setup
I'm prepared to go under the car with, I've been spending days under there. The front is resting on the same setup under the front chassis
rails.
Slimy38
posted on 13/4/20 at 09:02 AM |
Interesting photos, thanks. I don't understand why you're on the actual seam though? I am fully in support of spreading the load, I like
the idea of it being at least a foot long. But the jack points are actually each side of the seam, not the seam itself. Even the 'widow
maker' spare wheel jack doesn't actually touch the seam, it fits on the metal either side.
I can't really disagree with the pictures, it looks like that seam is staying intact. It's just not something I will be doing.
Mr Whippy
posted on 13/4/20 at 09:39 AM |
The sill is made from 3 sheets and the jacking point has extra metal there too, including the weld seam. If you looked at a cross section of the sill
you'd understand. The seam itself is the reinforced part, not the sill area either side of it.
The fun starts when jacking up older cars where the jacking point is weak and the jack just disappears through the sill lol fortunately this car is
fine.
coyoteboy
posted on 13/4/20 at 01:01 PM |
Having jacked on a car with a sill jacking point and appropriate pad and folded the sill, I always look for a better spot. Jacking on the seam is a
total no no for me unless you also contact the material either side to stabilise it - you just split the seam or fold it over and let water
penetrate.
[Edited on 13/4/20 by coyoteboy]
Report your local potholes, it actually works!
Mr Whippy
posted on 13/4/20 at 02:43 PM |
Well depends if there is an option, given a choice I will always jack on a hefty subframe or preferably one of the large bolts holding it on the car,
again with a pad of wood cos metal on metal is super slippery.
However if there are no subframes or suspension on the car... I'll jack on the sill near the jacking point and spread the load. I've had
to straighten plenty of sills in the past due to tyre shops jacking up on any convenient bit of body work. A good practice is to also put any removed
wheels under the car, so that if it falls you have some space left.
Slimy38
posted on 13/4/20 at 04:36 PM |
I agree, my preference is also some substantial bolt that is already load bearing or similar. The problem is the first thing I encountered when
looking under the car was plastic panels across most of the car. I can't identify the normal contact points I'd have expected to be
present. The sills are the only bare metal I could see.
The tyre shop fitting is an entirely different thing I've not yet figured out, so far the car has had it's tyres fitted at the dealer so
I'd hope they know how to lift the car. While it might seem overkill I'm tempted to take my wheels in my wife's car, same as I would
if I ever got my kit car finished.
coyoteboy
posted on 17/4/20 at 02:59 PM |
I was quite interested to see that the jacking points on my Nissan are unusual - the front subframe (not that unusual) or the rear diff casing -
nowhere else. The rest of the points (sills) are called out as lift points only for use when all 4 are used together or for safety stands.
https://www.350z-tech.com/attachments/jackpoints1-jpg.27421/
[Edited on 17/4/20 by coyoteboy]
