Author: Subject: Power Commander and oxygen sensor
roadrunner
posted on 15/6/20 at 05:57 PM Reply With Quote
I now have my exhaust manifold fitted.
When I came to fit the o2 sensor I realised that it is too small for the thread hole in the link pipe.
Is there an adaptor for the zx10r one that I already have or do I have to purchase a new car type and splice in.
Also because I'm using a Power Commander I thought I could cancel out the sensors but I can't seem to find how. And will the sensor need a spacer fitting.
Regards
Brad.
posted on 15/6/20 at 07:21 PM Reply With Quote
Weld in a standard M18 boss
https://www.ebay.co.uk/i/353105329523?chn=ps&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&itemid=353105329523&targetid=9 08661474856&device=c&mktype=pla&googleloc=9046918&poi=9046937&campaignid=10195651343&mkgroupid=103308028793&rlsatarget=pla -908661474856&abcId=1145985&merchantid=6995734&gclid=EAIaIQobChMInfORs8WE6gIVw1QYCh0cuQEqEAQYASABEgJBlvD_BwE
[Edited on 15/6/20 by britishtrident]
[I] What use our work, Bennet, if we cannot care for those we love? .
roadrunner
posted on 15/6/20 at 09:49 PM Reply With Quote
That would block the hole but what do I do with the o2 sensor and lack of readings for the ECU.
russbost
posted on 16/6/20 at 08:00 AM Reply With Quote
Power Commander is just a piggy back on the OE ECU, it can't "cancel sensors", but why would you want to?
The point of the PC is that you can control the fuelling so that it will pass a BETS test - the most difficult area to get right is lambda & you can increase or decrease fuelling at very low throttle openings (to get 3000 rpm as tested you're probably opening the throttle about 5% as the engine has no load
Why not just find out what the thread is on the Kawasaki O2 sensor & weld in an appropriate nut to the manifold, a car type sensor is just extra complication & expense surely?
Once in use most people would run the standard map unless you're going to get it rolling road tuned to allow for inlet & exhaust changes from standard
Furore Formula Car - the only two seater modern Formula Car lookalike. I no longer run Furore Products or Furore Cars Ltd, but would still highly recommend them for Acewell dashes, projector headlights, dominator headlights, indicators, mirrors etc, best prices in the UK! Take a look at http://www.furoreproducts.co.uk/ or find more parts on Ebay, user names furoreltd & furoreproducts, discounts available for LCB users.
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member   russbost 's Aim
roadrunner
posted on 16/6/20 at 09:28 AM Reply With Quote
I have downloaded a map that elimates the o2 sensors so I could just use the bung.
russbost
posted on 16/6/20 at 12:12 PM Reply With Quote
How certain are you of that, I thought the only way you can completely eliminate the O2 sensor was either with another bit of hardware kit from Power Commander or by flashing the ECU?
roadrunner
posted on 16/6/20 at 12:16 PM Reply With Quote
The map was downloaded from the Dynojet site, so should be reliable.
The eliminator kit they supply is just a blank for the exhaust and a blank to cover the electric plug.
I have found a car o2 sensor, so I can use that if necessary.
adithorp
posted on 16/6/20 at 01:07 PM Reply With Quote
So are you now just after a blank to screw in ?
Could probably find one for you. Think a pinto spark plug fits as well
http://jpsc.org.uk/forum/
roadrunner
posted on 16/6/20 at 01:21 PM Reply With Quote
I guess I'm just after confirmation that I'm going about it the right way. I can get the blank off ebay.
Thanks anyway.
