the_big_1
posted on 8/10/20 at 07:22 AM |
Header Tank Position
Hi Guys,
Guessing the rule of thumb with the header tank is that it should be the highest point to allow air to rise etc.
A part from the bulkhead, how have people located it so its still the highest point (If needed to be).
Locate at 2.0L Silvertop ideas etc.
Cheers!
Deckman001
posted on 8/10/20 at 07:31 AM |
I've not tried it as I don't have the type of system that could use it, but you might get away with using a pressure cap on the rad
instead ? that way the rad could be the highest point, but remember that you need a decent filling point so bear that in mind.
Jason
the_big_1
posted on 8/10/20 at 07:33 AM |
Yeah I thought that too but my rad hasn't got a filling point, I think its polo?
Deckman001
posted on 8/10/20 at 07:37 AM |
So you'll need to make sure you have a header tank then at the highest point, no other options i think for a workable solution. If you have
enough flexible pipework though, you might get away with a small header tank.
Jason
the_big_1
posted on 8/10/20 at 07:39 AM |
hi,
Yeah thought that was the case. Where is the highest water level on the engine that the tank has to be higher than?
Deckman001
posted on 8/10/20 at 07:54 AM |
quote: Originally posted by the_big_1
hi,
I'd assume that the rocker cover is just to be sure, and maybe even put a level across it towards the scuttle to ensure the cap is still the
highest point. while the car is sat correctly and with normal weights all round if possible, otherwise your positioning might be a bit out.
Jason
the_big_1
posted on 8/10/20 at 07:57 AM |
Hi ya,
Could only ever fit on bulkhead then lol
JAG
posted on 8/10/20 at 08:13 AM |
Water doesn't go any higher than the cylinder head - forget about the top of the rocker/camshaft cover. The top of the cylinder head is the
bottom of the rocker/camshaft cover.
I mounted my expansion tank under the nose cone and it works very well
Justin
the_big_1
posted on 8/10/20 at 08:16 AM |
is your head lower or level with the nose, not looked at mine to be honest lol
40inches
posted on 8/10/20 at 08:27 AM |
Header tank doesn't necessarily have to be the highest point.
Mine is 150mm below the heater and 50mm below the rad top and works fine
the_big_1
posted on 8/10/20 at 08:31 AM |
I guess its ok on yours as the rad has a fill point etc?
the_big_1
posted on 8/10/20 at 08:32 AM |
I guess the question is, if the rad fill point and header tank are lower than the top of cylinder head, how do we sort the air lock / bleed etc.
JAG
posted on 8/10/20 at 01:27 PM |
This ^ is true but the header tank SHOULD be the highest point to ensure the system can be bled and works as well as it should
Justin
the_big_1
posted on 8/10/20 at 03:10 PM |
Only issue I have I think it the coolant pipe I have at the rear, a Neil Dunne one, has a small pipe outlet facing up so pipe would be slightly above
the hight of the header tank. I guess a small inline bleed valve could be used?
Mr Whippy
posted on 8/10/20 at 03:32 PM |
bleed it on a hill
the_big_1
posted on 8/10/20 at 03:38 PM |
lol true. There is a small bleed valve on a well known auction site, used on caterhams etc,
https://www.ebay.co.uk/itm/New-in-stock-Caterham-Westfield-kit-car-Bleed-Tee-Coolant-valve/292744817013?hash=item4428f36975:g:A3cAAOxyqUpQ8xmU
I Could fit it just above the outlet at the rear.
